Old 07-02-2023, 04:30 PM   #1
ruturaj001
Drives: BRZ 2023
How noisy are Ohlins camber plates
I have read that camber plates are nosiy, don't have personal experience with them. Jack in savgegesse review said he couldn't get ohlins camber plates which are supposed to be less noisy. How noisy are the compared to other plates? Stock mounts?
In future I am planning to get ohlins R&T, so just doing research on camber options. Right now I am all stock except camber bolts giving me -2.4 degree camber. If I get coil overs, I would want -3.5 degree.
ruturaj001 is offline   Reply With Quote
Old 07-02-2023, 05:38 PM   #2
Hailwood
Drives: 2022 GR86
Can't speak to the Ohlins, but I've had the Raceseng plates for over a year and they've been super quiet even after a bunch of trackdays. Similar experience from my buddy who's had them on his 1st gen for 5+ years.
Hailwood is offline   Reply With Quote
The Following 2 Users Say Thank You to Hailwood For This Useful Post:
ruturaj001 (07-02-2023), whataboutbob (07-03-2023)
Old 07-02-2023, 06:08 PM   #3
StraightOuttaCanadaEh
Wes
I don't really understand the noise thing about camber plates, there is none to speak of. The OEM top mounts are rubber and aftermarket are solid metal so if anything the bumps will be more jarring, with the benefit of quicker responses to input. I've been driving on aftermarket top mounts for 6 years, summer and winter, rain and snow. No issues or noise to speak of.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 07-02-2023, 06:13 PM   #4
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
I was concerned going from Pedders & Koni’s to Ohlins but was pleasantly surprised that any noise wasn’t noticeable over tire noise and exhaust.
I’m running double camber bolts with the Ohlin top hats and can get -5 degrees camber when maxed out for track.
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS-V/EvoX Brembos
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. ECF on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
The Following User Says Thank You to Muskoka800 For This Useful Post:
Old 07-02-2023, 08:22 PM   #5
ruturaj001
Drives: BRZ 2023
I have stock suspension and can get -2.4 with both camber bolts. How much would you get with just ohlins top hat? I was thinking I wouldn't need camber bolts with ohlins and 20mm drop to get -3.5° or slightly more, seems like ohlins plates provide much less on their own.
Old 07-02-2023, 08:24 PM   #6
ruturaj001
Drives: BRZ 2023
I don't either but saw it being talked about at multiple reviews.
Old 07-02-2023, 08:35 PM   #7
ruturaj001
Drives: BRZ 2023
Old 07-03-2023, 11:38 AM   #8
Muskoka800
You may have spring to inner fender clearance issues with camber plates and stock diameter coil springs. Coil-overs use smaller diameter coils which allow further inward adjustment travel.
Another option you might consider while staying with stock spring size. Using double camber bolts and Pedders offset top hats. Close to -3.5 degrees is achievable. Pedders are like OEM top hats so do isolate vibration (noise) but with -.75 degrees negative camber built in. The cost is also much less that camber plates. Not as glamorous as camber plates but very functional.
Good Luck!
Old 07-03-2023, 01:44 PM   #9
whataboutbob
AutoX-10/10ths every run
I've probably had Raceseng plates for nearly 8 years at this point. No noise.
Build thread:Here
SOLD: Raceseng caster + camber - adjustable front camber plates higrip Brakes, Suspension, Chassis 4 09-17-2019 01:43 PM
What camber plates / top mounts for Ohlins? Jakecox86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 02-28-2019 02:28 AM
Question about adjustable LCA's vs Camber Plates vs Camber Bolts djdnz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 03-27-2013 11:38 PM
