Old 02-07-2023, 04:25 AM   #1
mr86lad
Drives: 2017 86 GTS
ECU TEK Issue
Hey all,
Bit stumped by this one! As are the tuners what does this error msg mean
The car is now turboed!
We loaded the new map fine but when we try and access the data logging we get this error has anyone come across this before?
Ps we also put a standard map on to see if it would create the same error and it does...
Has anyone come across the error before we' reached out to ECU TEK too as it's a very odd error.
Errror Message is Map Access Error Array index 4 is out of bounds on string 02 00 00
mr86lad is offline   Reply With Quote
Old 02-07-2023, 12:47 PM   #2
tomm.brz
Drives: brz 2017 hksv2
ecutek will know better, they usually answer in 1 day
Old 02-10-2023, 12:11 AM   #3
mr86lad
Drives: 2017 86 GTS
Cheers mate we figured it out it was an ECU Tek Issue
Key fob issue + physical lock issue Overdrive Issues | Warranty | Recalls / TSB 5 05-17-2023 03:36 AM
Idling issue after dyno (intermittent issue) FD3S Forced Induction 3 06-16-2022 02:55 PM
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 05:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 09:49 PM
A/C Issue? FUN BRZ Issues | Warranty | Recalls / TSB 5 02-08-2014 03:34 PM
