| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: 2013 Toyota 86
P1263, p0304 after spark plug change
Have changed spark plugs as I have a misfire.
I'm waiting on new coilpacks but was hoping the car would get better with new plugs. All I have done is change the spark plugs and straight after went for a test run. A full throttle pull in 3rd got a few pops then nothing, almost like someone turned the key off. I managed to get it home by resetting / clearing the codes but it only gives me 2 seconds of throttle before going into limp mode again. Any help is much appreciated ![]() Sent from my SM-S908E using Tapatalk |
#2 |
Drives: 2013 frs base
Did you replace and retighten the bottom bolt on the DI computer?
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (08-25-2022), Ultramaroon (08-25-2022) |
#3 |
#4 |
If you haven't already done so, check the connections to the DI computer and to the direct and port injectors, esp #4. There are 2 other ground straps. Check them too.
| Spark Plug Change from Under The Engine? | hachigoku | Engine, Exhaust, Transmission | 5 | 10-03-2021 11:08 AM |
| DIY: Spark Plug Change | thekevinvo | DIY (Do-It-Yourself) Guides | 22 | 12-15-2020 05:41 PM |
| Helpful DIY Spark plug change video | DTMdreaming | Engine, Exhaust, Transmission | 13 | 10-17-2020 09:55 PM |
| P1261 and 1262 after spark plug change | Remmenator | Issues | Warranty | Recalls / TSB | 2 | 05-20-2020 05:09 PM |
| Spark plug change - dealership price? | wparsons | CANADA | 47 | 05-08-2019 07:48 AM |
