Old 08-14-2022, 06:20 AM   #1
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Varex or Butterfly Exhaust Muffler
Hello 86s / FRS / BRZ / BMWs,
I am looking to get a butterfly valve exhaust and I know which one I want to get, but not 100% sure if installing a butterfly valve exhaust behind the CAT will cause issues. For instance, too much heat as the cat burns away gases created by the engine.
Hopefully someone can give me an idea as I've e-mailed some shops, but quite lazy reply's to be honest.
This the closest I could find to a compact exhaust muffler that can open and close, by Racecraft:
https://racecraftaus.com/products/el...lled-muffler-3
You may be asking why don't just put it at the back, well I have a TOMEI EXPREME TI TITANIUM EXHAUST and trying not to mess with its current cat back setup.
Any help would be great.
FRS2017 is offline   Reply With Quote
Old 08-19-2022, 07:23 PM   #2
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
My friend and I have a butterfly valve catbacks setup on our cars, but keep in mind that our set up has the valves are located way in the back where a typical briefcase muffler would sit.
Most of these butterfly valves can traced back to bulk wholesale items found on Alibaba and from our experience they do NOT like heat. The electronic motor that opens and shuts the butterfly valve may fail eventually. Personally that hasn't happened to me yet but there are rumors. Lastly, the valves will seize and get stuck either full open or full closed. My friend is dealing with that right now. Fortunately, we have warranty so our local muffler shop replaces them frequently (about once a year) no questions asked.
kevaughan is offline   Reply With Quote
The Following User Says Thank You to kevaughan For This Useful Post:
soundman98 (08-20-2022)
Varex Exhaust Availibility? saza26 Engine, Exhaust, Transmission 6 10-09-2020 02:07 AM
Variable Valve "Butterfly" Exhaust dlux Southern California 19 02-22-2016 07:21 PM
Varex Exhaust - Loud to Quiet Anytime You Want! Canehda Engine, Exhaust, Transmission 19 05-31-2015 09:52 PM
FS: Varex Single Exit Exhaust -> $800 Canehda Canada Classifieds 8 11-13-2014 08:07 PM
because streetcar / because racecar my custom ft86speedfactory varex exhaust mad_sb Engine, Exhaust, Transmission 31 05-28-2014 03:43 AM
