Drives: 2013 Subaru BRZ
Retro Fit PP Brembo Brakes - Questions
I have a set of PP Brembos to retro-fit on my 2013 BRZ. I have been unable to find the answers to the following questions, perhaps there may be others that are familiar with the swap that could assist:
1) Are my existing (stock) 2013 brake lines compatible? 2) The rear mounting caliper bolts - will my existing bolts suffice? (I have bought new ones for the front calipers) Thanks |
#2 |
Drives: Corolla GT
The brake lines will fit.
As for the rear bolts, you will need new ones, I think. |
#3 |
Thefalls - thanks
#4 |
By way of follow-up to this thread, yes new bolts were required on both front and rear. The front bolts are longer (to accommodate tie bar) and the rear bolts a different pitch.
Also, whilst the brake lines fit there is a curvature to the banjo bolt steel sections that is different on the Brembo ones - therefore do not suggest using non-oem brake lines on Brembo calipers. For anyone reading this, also note that new front and rear dust shield plates are required (unless you want to butcher your existing ones with an angle grinder which I don't advise. you don't want cut metal edges near brake hoses) |
#5 |
Also, whilst the brake lines fit there is a curvature to the banjo bolt steel sections that is different on the Brembo ones - therefore do not suggest using non-Brembo brake lines on Brembo calipers. For anyone reading this, also note that new front and rear dust shield plates are required (unless you want to butcher your existing ones with an angle grinder which I don't advise. you don't want cut metal edges near brake hoses) |
#6 | |
Drives: 2013 FRS
#7 |
Drives: 17 BRZ
just incase you haven't seen the thread for the PP brembos:
https://www.ft86club.com/forums/showthread.php?t=144662 I had a shop install mine but yea loving the brembos everyday
| CSG Brembo Brakes | LenA | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-12-2024 11:05 AM |
| WTB: OEM Brembo Brakes or BBK | lc300 | Canada Classifieds | 13 | 11-03-2021 10:29 AM |
| 2017 PP oem BREMBO Brakes | FT86Logic | Brakes, Suspension, Chassis | 5 | 01-27-2019 04:07 AM |
| EVO 7 BREMBO FRONT BRAKES ON BRZ? | NOTORIOUS.BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-26-2016 01:24 AM |
| Evo X brembo brakes | Justkiz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-12-2013 03:00 AM |
