Old 05-28-2022, 12:14 AM   #1
blueskiesgreenlights
Drives: 2020 86
Mystery Spade
I'm installing a digital rear view mirror (https://amzn.to/3LP4ynX ) but before I hardwire the power supply and use a back plate to replace the strap security setup I want to test it for a while to make sure it is a reliable device.
The problem is the cigarette power supply doesn't work. So far I've removed the head unit and half the dash but I can't seem to find where this spade plugs into. Does this spade look familiar to anyone and, if so, where is the plug connection?
The fuse is good and the digital rear view mirror powered up on a neighbor's car so my hope that my assumption that this spade is related to the cigarette lighter and by connecting it I can test the device.
Here's a couple of photos of the spade below. It is covered with a transparent sheath and is located behind the radio. The wire is dark blue with a black stripe.
https://i.postimg.cc/RhTKxHSB/IMG-20220527-210135.jpg
https://i.postimg.cc/kMjgzs95/IMG-20220527-205959.jpg
My guess is that I've spent so much time and effort checking wiring and replacing head units that the electrical connection came apart.
Thanks!
blueskiesgreenlights is offline   Reply With Quote
Old 05-28-2022, 02:00 AM   #2
p1l0t
p1l0t's Avatar
Just find 12V and splice it in
blueskiesgreenlights (05-28-2022)
Old 05-28-2022, 02:45 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It’s supposed to be blank. When you buy a trac box from GJP that is where it plugs in so I believe it is a com port for CAN. You can see it’s mate in the pictures on the trac box pictures.
https://www.geraldjustprojects.com/p...gt86-trac-box/
cigerette lighter spade
RiP Kate Spade Jordanwolf Off-Topic Lounge [WARNING: NO POLITICS] 19 06-07-2018 05:16 AM
Mystery problems Ashikabi Engine, Exhaust, Transmission 10 04-04-2016 11:29 AM
mystery body kit... (no longer a mystery) Alita Cosmetic Modification (Interior/Exterior/Lighting) 3 08-16-2015 07:10 PM
NEW ADR SPADE 18" Rims $300 raven1231 Wheels and Tires 0 06-02-2015 03:08 PM
MAF Mystery! KoolBRZ Software Tuning 14 12-08-2014 07:11 PM
