Old 07-01-2022, 01:29 PM   #1
Kūsho
Drives: 2018 50th Anniversary BRZ
Air Bag SENSOR Cross-Compatability
So I was involved in an accident with my 2018 Subaru brz my passenger Air bag went off above the door panel with no passenger in the seat. I have one simple question and I am in need of immediate response, as this is the final part needed to have my vehicle back from the shop. Subaru has the sensor on backorder with no ETA. Does ANYONE have any knowledge about if the Toyota 86's sensors will work for the Subaru BRZ???
Thank you to any and everyone who respond!
Kūsho is offline   Reply With Quote
Old 07-02-2022, 11:07 AM   #2
They are identical parts with different numbers to match the stock system for each.
Odds are if Subaru is back ordered the Toyota part number will be as well though.
Old 07-02-2022, 11:09 AM   #3
Kūsho
Toyota has them in stock. I just need to know if the Toyota sensors will work on the BRZ. Subaru has them on backorder w no ETA, Toyota can get them in 3-4 days
Old 07-02-2022, 11:29 AM   #4
Exact same parts.
Old 07-02-2022, 11:33 AM   #5
Kūsho
Exact same parts.
So will Subaru's system software read the Toyota sensors correctly and activate the airbags properly?
Old 07-02-2022, 11:39 AM   #6
Exact same means exact same. There are very few actual differences between the two including software.
Old 07-02-2022, 11:45 AM   #7
Kūsho
Is there any proof of this? Have you personally used Subaru's sensors on your 86? (BTW, sick that u have the Hakone edition) I don't doubt your credibility, I just need to present the body shop with as much evidence as I can in order to have them order this part from Toyota. THEY said the parts are not the same.
Old 07-02-2022, 12:22 PM   #8
They are the same car built in the same plant with the same parts.
The only reason the parts have different numbers is that the two companies use different systems to identify and track inventory.
Not sure how this could be “proven” to them though.
Grady (07-03-2022)
Old 07-02-2022, 03:21 PM   #9
villainous_frx
Off to the track!
villainous_frx's Avatar
Drives: '14 Lava 86, '13 WRB BRZ
Friend is using a an 86 airbag sensor/occupancy sensor in his BRZ, no issues.
villainous_frx is offline   Reply With Quote
Old 07-03-2022, 02:52 PM   #10
Grady
Grady's Avatar
Install sensor, run into wall at 50 see if the airbag deploys.
Chances are Subaru nor Toyota makes the sensor. Look for a manufactures part number on the old and new sensor. Guarantee they are identical except for the box they come in.
airbags, subarubrz, toyota 86
Fan\Shroud compatability with JRSC dual oil cooler and radiator Ignore Your Doctor Engine, Exhaust, Transmission 1 11-23-2020 11:38 AM
86 hood to BRZ compatability leevanf Cosmetic Modification (Interior/Exterior/Lighting) 15 06-17-2018 09:06 PM
Oxygen sensor cross threaded. Zaneman Issues | Warranty | Recalls / TSB 13 07-05-2017 01:14 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Right Hand Drive - Exhaust System Compatability Blighty Engine, Exhaust, Transmission 2 06-21-2013 02:00 PM
