Old 10-27-2021, 01:49 AM   #1
TrashFRieS
Drives: 2013 Scion FRS
Exclamation 2013 frs, attmepted repairs to fix gas leak, ended up worse than when i started
I'm at around 3 months of ownership and I'm close to just giving up on this platform.
i posted a thread a while ago discussing the engine failure I was experiencing within the first month of purchasing.
this required a new short block and oil pan.
SINCE the installation of the new short block I've experienced a slew of new problems listed out here:
1) dealership rewired in the VIPER remote start incorrectly, causing the main fuse to blow, leaving me stranded, twice.
2) experiencing an audible and smell-able gas leak after turning the car off
3) as a result of trying to diagnose and repair the gas leak, I'm now dealing with rough idling and intermittent loss of gas pedal response
__________________________________________________ __________
what I know :
-the leak is coming from, the hose located under the bottom left hose of the intake manifold
__________________________________________________ ___________
what was attempted:
-got a mobile mechanic to come out and try to diagnose/fix the leak
-disconnected all intake hoses
-disconnected negative battery terminal
-disconnected ECU
-disconnected the fuel line covers to gain access to the area leak appears to be coming from.
-disconnected throttle body
- removed bolts holding the intake manifold down
what leads to the nightmare situation I find myself in:
at about 7 hours into the job, my mechanic, with everything described above disconnected and removed, jumps up and goes "OH SHIT I FORGOT MY SON HAS A DOCTORS APPOINTMENT!!" and just leaves. this was 2 days ago and last I heard from him, he's 2 states away, with my obd2 scanner, doing a different job.
SO...
my brother and i did our best to get everything reconnected, and to our credit, the thing starts, runs (kinda), and turns off ALL WITHOUT CATCHING ON FIRE (i consider this a win) ((my wife does not))
I now have a car that bounces between 1-2k rpms at idle, randomly loses power and/ or gas pedal response, and is overall, a gigantic fucking headache.
I'm going to buy a new scanner in the morning and will update with specific codes.
any advice for solutions?
I'm at my wits end with this car and I just need to get it functioning again and really don't have the resources to pay another $8,000 to Atlanta Toyota to have it "fixed" again. any help is appreciated and i hope you are all having a better day than I am
TrashFRieS is offline   Reply With Quote
The Following User Says Thank You to TrashFRieS For This Useful Post:
humfrz (10-27-2021)
Old 10-27-2021, 03:29 AM   #2
UGH - what a mess -
Yes, start by posting the codes your car will be giving you.
TrashFRieS (10-28-2021)
Old 10-27-2021, 03:53 AM   #3
fableluke
Drives: BLue 2013 frs
Codes will be the best start. AND, was that leak under the intake manifold ever addressed when it was put back together?
fableluke is offline   Reply With Quote
The Following User Says Thank You to fableluke For This Useful Post:
Old 10-28-2021, 02:02 PM   #4
TrashFRieS
The codes im getting are:
C1201
C1231
C1234
C1294
U0073
U0100
U0101
Old 05-06-2022, 12:26 AM   #5
TrashFRieS
Just remembered I never closed this thread out, turns out the leak was from a bad injector. And the slew of codes I got thrown was from not tightening down an ECU amounting bolt enough. Tightened it down and thing ran perfectly
The Following 8 Users Say Thank You to TrashFRieS For This Useful Post:
bcj (05-08-2022), Code Monkey (05-07-2022), Decep (05-08-2022), Lantanafrs2 (05-07-2022), soundman98 (05-06-2022), Tatsu333 (05-08-2022), Wally86 (05-17-2022), x808drifter (05-06-2022)
Old 05-07-2022, 11:43 PM   #6
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Glad to hear things finally worked out for you. I'll admit, it's never fun trying to fix a problem cause by the previous owner... That's why I would never buy a modified vehicle.
The real question remains, did the mechanic come back and return your scanner??
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 05-16-2022, 02:44 PM   #7
TrashFRieS
Found out a few months back he’s in prison now. Cut my losses, bought new scanner
The Following 2 Users Say Thank You to TrashFRieS For This Useful Post:
Code Monkey (05-16-2022), Wally86 (05-17-2022)
repair
2013 Gas Cap Leak ? Helturus Issues | Warranty | Recalls / TSB 6 03-06-2020 11:35 AM
2013 BRZ Oil Leak yablonskiy11 Issues | Warranty | Recalls / TSB 5 03-23-2019 02:46 PM
Can't Turn After Wreck Repairs Strife26 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 02-26-2019 07:44 PM
Argh - spotted the dreaded OIL LEAK on my 2013 BRZ exE36M3 Northern California 0 01-24-2016 06:24 PM
Looking for a place to get repairs done discretion Mid-Atlantic 1 11-28-2015 06:38 PM
