Old 01-26-2022, 09:51 PM   #1
cnorman
Clutch replacement
What is a reasonable price for a clutch replacement on a 2013 brz. Just got quoted $3,300.
cnorman is offline   Reply With Quote
The Following User Says Thank You to cnorman For This Useful Post:
humfrz (02-15-2022)
Old 01-27-2022, 04:44 AM   #2
cpxchewy
Drives: 2022 BRZ
What.
Did inflation hit that high already? Should be 4-6 hours to do at a shop + ~$450 for Exedy OEM Clutch and Flywheel. Unless your shop is charging $500/hour you're getting ripped off massively.
cpxchewy is offline   Reply With Quote
The Following User Says Thank You to cpxchewy For This Useful Post:
NoHaveMSG (01-30-2022)
Old 01-27-2022, 10:10 AM   #3
thekevinvo
Drives: 2014 Scion FRS
If you want to save some money and do it yourself, you can use this guide:
thekevinvo is offline   Reply With Quote
The Following User Says Thank You to thekevinvo For This Useful Post:
RedReplicant (01-29-2022)
Old 01-29-2022, 09:03 PM   #4
RedReplicant
Drives: None
A friend that is a Honda tech offered to do mine on the side for $300 in labor, which I thought was pretty reasonable, however I ended up doing it myself since I found some free time. He said he can get one done in a couple of hours, this was my second time around in the span of 3 weeks and it took about five hours on the floor in the garage.
Obviously you can probably beat what I spent on parts:
$33 for OEM clutch release fork
$35 for OEM throwout bearing and all three clutch fork clips
$29 for Verus clutch pivot
$279 for Exedy OEM clutch / pressure plate / throwout bearing / pilot bearing kit (didn't use the throwout bearing since it clearly isn't the same as the OEM updated one)
$25 for 2l Motul gear oil (had another left over quart from the other car)
About $400 in parts and $300 in labor is about as cheap as it gets if you can't do it yourself. If the throwout bearing was seized for a while you might end up needing a $75 transmission "Front Bearing Retainer Cover", otherwise known as the thing that the throwout bearing rides on. If the car has higher mileage or the flywheel is torched it'd be another $175 for that.
RedReplicant is offline   Reply With Quote
The Following 2 Users Say Thank You to RedReplicant For This Useful Post:
CincyJohn (02-04-2022), Ultramaroon (01-29-2022)
Old 01-29-2022, 09:13 PM   #5
I think for Brits at least, it's called a quill.
Old 02-07-2022, 10:56 PM   #6
Decep
Drives: 2013 FR-S Series 10
I spent 700$ a few years back. I know inflation is koo-koo but your quote is way out of line.
3k is one of those quotes where the mechanic doesn't want to deal with it, but will, at a crazy price. Or his daughter just got braces or something, yeesh.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 02-07-2022, 11:32 PM   #7
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I had it done at the dealer in 2019 for <1400$ with a few extras.
Stock clutch, new flywheel, new TOB, new tranny fluid and new diff fluid.
The Following User Says Thank You to Yoshoobaroo For This Useful Post:
x808drifter (02-08-2022)
Old 02-15-2022, 03:24 AM   #8
I reckon you need to get further away from Norman and get another estimate
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 01:35 PM
OEM-like clutch replacement B-R-Z Engine, Exhaust, Transmission 31 02-22-2020 05:27 PM
Is $1600 for a clutch replacement too much? Rohint75 Engine, Exhaust, Transmission 33 08-22-2018 02:05 PM
Clutch replacement pinetree Engine, Exhaust, Transmission 21 05-03-2017 09:48 AM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 05:22 AM
