| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2014 BRZ
Just got my BRZ and I have some wheel and tire questions. It's my daily but I also want to take it to some autox events because I've been getting into that recently. I've been looking at some 17x9 +38 Gram Lights 57cr's but I have no idea if this is a good setup for autox. Also I don't know what tires to go with. I was looking at a Falken Azenis RT615K Plus 255/40R17 but I'm not sure if that's too aggressive for the street. I'm also on stock suspension but might get lowering springs. Anything helps, thanks!
#2 |
Drives: '13 FRS - STX
Yes, 17x9 is the standard wheel size for STX competition. The falkens aren't very sticky but they're affordable and durable, a reasonable step into better tires, rt660 are stickier and faster. Both will be fine on the daily but will have some compromises like noise. 245/40/17 is the standard STX size but 255 isn't bad, more of a preference thing or trying a taller tire to mitigate the short gearing on the facelift car.
If you're not building for a class get what makes you happy. A052 are the "best" autocross tire right now but the falken 660 are basically just as quick in most cases while being cheaper and reportedly lasting longer. |
#3 |
Moutain Runner
Im using 17x9 57CRs. They do fine.
#4 | |
Drives: 2014 BRZ
#5 |
Drives: 2014 BRZ
#6 |
Drives: 2013 BRZ Sport-Tech
57CR's are nice but as I recall when I was looking into wheels for my track setup there are a number of lighter options in 17x9 (may matter depending on how competitive you want to be).
#7 | |
SSC - 17x8 +40 or higher, 225/45/17 rt660 spec tire, need spec suspension STX - 17x9 any offset, tire <265, a052, rt660, BFG rival s 1.5, 245/40/17 is typical but other sizes may work well DSP and up - the widest wheels and tires you can fit, either a7 (csp/DSP, sm) or yokes for XSA |
#8 |
Drives: 2017 BRZ PP, 2004 WRX
If you're on the stock suspension right now and 'might' get lowering springs, you probably don't need a 17x9 with a 255.
With autocross, you really have to think about what class you want to go with. If you're just getting started, get some 17x7 wheels and a good 225/45/17 to learn on. Something like the Conti ECS for even those Falkens you mention. Get out there, have fun, and learn in a street class. Worst thing you can do is slap on some 255's for multiple reasons. First, this bumps you to STX, which you'll instantly be noncompetitive in and will probably lose interest in autox as a whole. Second, the 255's a wide tire, thus covering us driving mistakes - but admittedly not as bad as running 255's in a super sticky tire like the Yoks/RT660's. Third, 255's weight a good bit more than 215/225's, so even though you're keeping the wheel weight the same, the tire weight goes up, and being on the outside of the wheel setup, the car will be slower in a straight line now too. Lowering spring comment too - most lowering springs are crap. Not enough spring rate for the right height change, so you end up negatively effecting handling for autocross because it's likely you'll hit the bump stops on hard corners, effectively sending your spring rate through the roof and upsetting the car. Upgrading the struts on a 2014 keeps you in the street class and is going to give you a better daily ride too - I'd spend your money there and possibly with a front swaybar to combat the body roll (again, keeping you in street class). If you do go the 17x9 route with 255's, just understand you're probably stunting your driving growth longer term. And if you're doing that, at least go with an STX-lite build with a header, tune, front swaybar, and coilovers over lowering springs (much better). Doesn't mean you need to build it exactly to the class, but at least that gives you a fighting chance locally at events. Again, I'd still say stick to the stock class initially. I do get that a lot of people don't aim to be competitive and just want a car to look good with wide wheels/tires and lowering springs. But I do think it's not the right path if it's something you want to get into on even a moderate basis. I see way too many people show up with all kinds of cars, random modifications, get put in higher classes, get destroyed, and not come back or lose interest. I've also see a fair share of drivers run modified cars, rely on the car's mechanical grip, and not develop as a driver well.
| The Following User Says Thank You to cmiovino For This Useful Post: | grumpysnapper (09-24-2021) |
#9 | |
Drives: 2014 BRZ
#10 |
You might also look at SSC, it's a spec class and considerably less expensive than STX. I'm on the Falken 660, it's a nice tire to autocross on and that's what the class uses.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
#11 |
Drives: 2017 BRZ
I can not recommend autox tires for commuting. Loud, expensive, and they hurt gas mileage. Loud is the hardest part though.
Of course, I don't worry about stuffing the wheel wells... I'm driving it, not staring at it in a showcase. I use a 225/45 on a 17x8. Still on aging PSS but it doubles as my "cones are floating away, it's a lake" rain tire for autox. Technically that's a fine wheel to use. It might have some clearance issues stock? Either spring perch or fender are the usual. Not sure. STX drivers are usually on smaller springs and a good deal of camber, so don't have fit issues.
#12 | |
Drives: 2014 BRZ
#13 | |
TRACKBREAD
Autox and daily wheel tire setup
If you’re going to go with cheap coilovers, I’d get ST XTA coilovers. They’re the only cheap set that are TUV approved and they’re made by KW. A good alternative would be the CSG coilovers by Tein. Last edited by Yoshoobaroo; 09-27-2021 at 06:40 PM. |
#14 | |
Drives: 2017 BRZ
Save up and do it right the first time. T2 or KW V2 are certainly quite good options and also do well if you DO run them where roads are salted. There are plenty of other options - lots of this available over in the Track/Autox section here. If you really want to go in at $1500, keep an eye out for something used, or consider the options Yosh provided.
| Best Daily Wheel/Tire Set up | JR Whiter | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 05-03-2020 09:45 PM |
| SM wheel and tire setup | aquaman | Tracking / Autocross / HPDE / Drifting | 8 | 10-28-2015 02:53 PM |
| Good wheel/tire set up for daily driver | Oburn | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 0 | 07-10-2013 03:21 PM |
| WTB: Track / AutoX Wheel and Tire Setup | n8dog11914 | Wheels and Tires | 3 | 06-17-2013 07:42 PM |
| tire/wheel setup? | kosoku | Tracking / Autocross / HPDE / Drifting | 0 | 11-25-2012 10:53 PM |
