Old 08-31-2021, 07:45 AM   #1
J95
J95's Avatar
Will tracking the car "damage" my wheels?
I own a set of Gramlights 57CR bronze limited edition. I use them for daily but I will start tracking the car from time to time. These wheels are very limited and almost imposible to get in Europe, so I am worried about wearing out or damaging the wheels in excess because of the tracking
I would buy a set of wheels like Autec WIZARD only for tracking. But I really don´t have space at home to keep them. Also I will be moving out of the country in 2 years
So my question is, would you advise me to not track the car until I am able to get new set of dedicated wheels, or should be fine to use my beloved wheels for that? How much can the wheels be worn out during several track days?
J95 is offline   Reply With Quote
Old 08-31-2021, 08:06 AM   #2
ZDan
ZDan's Avatar
Drives: '23 BRZ
Decent wheels that are TUV or JWL approved should last practically a lifetime of street/casual-track usage. I would expect Rays/Gramlights to be fine.
Always a good idea to inspect hem periodically! Do a search on them to see if they're known to develop cracks, and if so where.
I had a set of aftermarket "racing" wheels (not Ray's or any other major brand) that were fine, but after I got them learned that some had cracking issues. Sure enough, after a couple of seasons on them I found tiny hairline fractures in a couple of them, right where they are known to crack... Never would have noticed if I hadn't cleaned them and inspected critical areas closely...
Old 08-31-2021, 10:39 AM   #3
CrowsFeast
CrowsFeast's Avatar
Drives: 2013 BRZ Sport-Tech
I also would expect them to be fine. Being a limited colour (which I presume you like) you'll want to clean the brake dust off in a reasonably timely fashion after your track day. Can get rather ingrained in the wheel finish and 'stain' them sometimes.
CrowsFeast is offline   Reply With Quote
Old 08-31-2021, 10:54 AM   #4
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I would think you would be more likely to damage your light rims on the street.
Read this on a wheel manufacturer 's site years ago. Doesn't really answer your question, but something to think about.
Wheels are similar to shoes that we wear. We have shoes for running, hiking, office, and cross training. Each require specific design considerations to optimize their respective performance. So why not wheels? Wheels that are subject to road use contend with constantly changing load, road imperfections, higher volumes of hot cold cycles, and real world conditions that often require added fortification to ensure consistent performance over a longer duration than that of a race wheel that will usually have a shorter lifespan with a focus on the lightest possible weight. Similar to race engines that require rebuilding in shorter intervals than street engines, a racing wheel should not be considered over a street wheel with the sole consideration of weight. In fact, weight savings of 30 lbs or less end up yielding minimal gains in performance vs the limitations it presents to the proper use of the vehicle.
Old 08-31-2021, 11:40 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
They will be fine as long as you don't have a bad off, and an off like that would likely damage a lot more then the wheels.
Old 08-31-2021, 12:14 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Keep on the track and avoid the kerbs that are less than friendly. A good wheel is fine for track duty
TommyW is offline   Reply With Quote
Old 08-31-2021, 04:27 PM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
Bear in mind that an off-track excursion will likely chip the paint on your wheels.
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 08-31-2021, 09:52 PM   #8
Pat
Pat's Avatar
Drives: 2023 BRZ
I disagree. I've been off the track many times over the last 20 years and the only wheel damage I can remember is from hitting a wall. Sliding sideways through rocks is a different story, of course.
Old 09-01-2021, 05:46 AM   #9
J95
J95's Avatar
Thank you all for the answers!
Nice! Now I am more confident to go to tracks until I can get a dedicated set of wheels for that
Old 09-01-2021, 05:42 PM   #10
Purist
Purist's Avatar
Drives: Subaru BRZ
Fair call, Pat. I should've said possibly, instead of likely.
Less More
Old 09-02-2021, 12:44 AM   #11
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
@J95 The wheels likely won't wear out from track days, but there is a real risk of bending them going over bumps or dropping them in ditches that they aren't meant to go over (depending on what course you go to and the track condition there).
You never intend to go off-course, but if you're pushing it the risk is always there. It could be as simple as cutting the corner of an apex.
EndlessAzure is offline   Reply With Quote
Old 09-02-2021, 04:57 PM   #12
CrazyWookiee
Drives: Whiteout FR-S
When you start tracking, your wheel becomes a consumable.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 09-02-2021, 05:44 PM   #13
ZDan
ZDan's Avatar
Drives: '23 BRZ
If you buy *racing only* superlight wheels, yeah. They're not designed for a tremendous number of load cycles. Or if you buy sub-par aftermarket wheels that haven't been properly analyzed and tested, also yeah. But *good* aftermarket wheels will last a *really* long time for street and track duty.
For sure "they're a wear item!" is the number one go-to excuse for aftermarket wheel designers (more stylists) who haven't put in the analysis hours and the test miles to prove out their designs.
Tracking the F's Gearbanger Tracking / Autocross / HPDE / Drifting 13 08-07-2016 05:42 PM
I love tracking this car kurbkilla Tracking / Autocross / HPDE / Drifting 4 04-21-2014 08:14 PM
Oil and tracking? SavingManuals Scion FR-S / Toyota 86 GT86 General Forum 11 07-04-2013 05:38 AM
Who's tracking their BRZ? random hero BRZ First-Gen (2012+) — General Topics 11 08-20-2012 10:30 PM
