Old 11-05-2018, 10:37 AM   #1
wild03
Drives: Silver 2017 Limited with PP
2017 BRZ trunk hard to close?
Hi all, been about 2 months with mmynew 2017 BRZ and since i got it the trunk has been hard to close, Such a contrast fromthe doors that i just close with barely any effort, I just push the door close onthe last 2 inches of travel a light push and the door closes nicely.BUT THE TRUNK its a different story. I have to start about a foot from high and ram it down or else the trunkjust bounces back...I thought it needed time but nothing has changed.
Anyone else noticed this? any tips?
wild03 is offline   Reply With Quote
Old 11-05-2018, 10:39 AM   #2
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The trunks on these cars have always required a bit more effort than you like to think they should require. It's no different on my 2015. You have to half slam it to get it to properly close, and the same goes for just about every other twin owner I know, lol.
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 11-05-2018, 10:56 AM   #3
cliff
Drives: subaru brz
I concur.
cliff is offline   Reply With Quote
Old 11-05-2018, 01:33 PM   #4
bmxr
bmxr's Avatar
Drives: 2017 BRZ PP WR Blue
Pressing down from the middle of the trunk helps a little.
bmxr is offline   Reply With Quote
Old 11-05-2018, 01:38 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I've never though mine was anything out of the ordinary. Mine is wingless. With a wing you have stiffer hood shocks.
I always push down on the license plate. No fingerprints
tCsonfrs (11-08-2018)
Old 11-05-2018, 02:21 PM   #6
Maybe adjust the trunk latch -
Old 11-05-2018, 02:26 PM   #7
ShansBRZ
Drives: 2017 brz
My 17 is the same way. Pretty much have to slam it to latch.
ShansBRZ is offline   Reply With Quote
Old 11-05-2018, 02:42 PM   #8
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Normal.
Start working out more.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
alphasaur (11-06-2018)
Old 11-05-2018, 03:51 PM   #9
wild03
Good one, I just don't want the wing to fly off, i noticed it is not attached in the middle, and I can feel it bounce each time...definetly not a good idea to push down on the wing to close it, i imagine it would dent the trunk eventually.
i suspect the rubber bumpers are on the tight side to prevent trunk from rattling... oh well. Thanksfor the replies.
The Following User Says Thank You to wild03 For This Useful Post:
8RZ (11-05-2018)
Old 11-05-2018, 04:29 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Glad you can take a joke. I wouldn't be too worried about the wing breaking.
Current DD: M235i
Old 11-05-2018, 04:44 PM   #11
spike021
spike021's Avatar
Ideally you use two hands. One holds the wing for support, and the other helps close the trunk from a bit more to the side of the middle.
But yeah, @humfrz is probably right about the latch. I've always wanted to try adjusting it myself but haven't gotten around to it.
Another thing I've noticed about my trunk that may be related is that the trunk itself isn't centered. Like if you compare panel gaps on the left and right sides, they're quite different. So it's possible even that the trunk isn't centered properly and that's why the latch doesn't catch it very well.
edit: meant to say it's possible that my trunk *isn't* centered properly [...]
Instagram: @spike.grc
spike021 is offline   Reply With Quote
The Following User Says Thank You to spike021 For This Useful Post:
humfrz (11-05-2018)
Old 11-05-2018, 07:26 PM   #12
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
2017 86, yeah the trunk can be relatively hard to close compared to the doors that beautifully click shut.
Typically, small trunks like these have gooseneck hinges with flimsy torsion springs and once you're halfway down they almost slam shut by themselves, out little light trunks have much sturdier hinges and and gas struts, so yeah they require a more deliberate movement.
Old 11-05-2018, 07:52 PM   #13
highway7
Drives: FRS 2013
MY trunk doesn't have any problems. I would take off the plastic trim and adjust the striker plate
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
humfrz (11-05-2018)
Old 11-06-2018, 03:19 PM   #14
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Inspect the striker plate as well -- the rubber bumper on mine split apart ~15k miles, and the latch was hitting the metal. The dealership had to replace the striker plate and latch to the tune of $200 (under warranty) just because the little rubber piece broke.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
2017 Toyota 86 Trunk Lid GrayFox_27 Want-To-Buy Requests 0 06-23-2018 02:48 PM
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 07:09 PM
TRADE: 2017 BRZ trunk and wing for wingless trunk?? Moto CANADA 0 05-19-2018 05:21 PM
WTT 2016 limited trunk for 2017 trunk Ignore Your Doctor Southeast 0 08-27-2016 11:32 AM
