Drives: FR-S 2013 Asphalt
Alternator Options
For those of us running or looking to run massive amperage drawing systems, what alternator options are you considering?
I haven't seen any increased amperage alternators for the FR-S/BRZ/GT86. Does anyone have a link to the stock max alternator output? Some considerations: Smaller diameter pulley on the alternator Dual alternator installation Replace with higher output ALT. Any other suggestions? |
#2 |
KCCO From Canada
Drives: Asphalt FRS
i looked here for Scion TC alternators might be the same size. but i havent really considered buying one. im sure someone could chime in about whether it would work or not.
https://www.dcpowerinc.com/high-outp...2.4L+I4+2AZ-FE |
#3 |
First 86 Driver Baby!
Drives: FR-S, Flex
Maybe look at Subaru replacement alternators, since it is a Subie engine.
| The Following 2 Users Say Thank You to kmbkk For This Useful Post: | SirBrass (04-10-2014), Sportsguy83 (02-27-2013) |
#4 |
Thank you FreshFRS and kmbkk!
I'm considering the second alternator setup. I'll have to look around in the engine bay to see where I could weld up a second alternator bracket. I'll post pictures later (likely Saturday) with the proposed spot for scrutiny and commentary. http://powerbastards.com/proddetail....od=Fitzall-220 ^ any opinions on this brand? |
#5 |
Drives: SSM LT MT BRZ
So apparently none of you looked at the alternator before asking this???
It says on the label of the alternator that it is a 130A alternator. please be mindful that this car already has a significant load due to the 90-100V required to open the DI against upwards of 200 BAR fuel rail pressure..... |
| The Following User Says Thank You to SkullWorks For This Useful Post: | shiro (05-23-2013) |
#6 | |
The system I am putting into this car crashed my alternator on my first build. Installed a high output, but still had headlight dimming issues, so I'm looking for advice and I will have a DIY for whatever I do to be informative for others with this vehicle wishing to install heavy draining audio systems or additional electronics. So, this thread is about what is the best choice for this car (based on availability, cost, ease of use, effectiveness) |
#7 |
Drives: FRS 2013
Curious as well
#8 |
Mike Singer Alternators is able to make a 275a stock alternator replacement.
#9 | ||
Frosty Carrot
Drives: The Atomic Carrot
I've had good experience with Excessive Amperage, Nations Auto Electric, Mechman, and others. I've contacted Nations, but awaiting a response.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX Wall of Shame - aFe Takeda, Wilwood, FA20Club |
| The Following User Says Thank You to Shankenstein For This Useful Post: | FreshFRS (04-10-2014) |
#10 |
Trust me, I'm the Doctor
How much more engine power does it take to run it, though? I doubt you can get that much additional amperage just by upping the alternator efficiency, and there's always TANSTAAFL to consider. That extra electrical power has to come from somewhere, after all.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#11 |
Just got the Mike Singer 275A alternator last night, by hand it didn't feel all that much more difficult to spin. I see what you are saying. I'll have to ask how it's done.
| The Following User Says Thank You to AtlasMick For This Useful Post: | SirBrass (04-11-2014) |
#12 |
Just a dude
Drives: Scion FR-S 2013
Are we concerned about massive sub draw? I thought same some decent D10 charge caps do the trick I've tested a 5.1k audison with two 10" no issues or dimming etc when car was running... Unless you're going all out like a stereo comp set and don't want to run caps I don't see the need. (For now) anyhow.
#13 | |
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
#14 |
Definitely has a higher spin rate. The pulley is somewhere near half the diameter.
I opted for the externally regulated version, so I have quite a bit more install work to do prior to having the Singer alternator operating. I hooked up the stock alt to an ammeter see what it's current output was at idle right after cranking. 30 amps. Last edited by AtlasMick; 04-11-2014 at 09:39 PM. |
| Alternator pulley torque setting?? | ahaghshenas | Engine, Exhaust, Transmission | 4 | 07-27-2014 09:03 PM |
| Bushing upgrades, geometry options and other component options? | der_rainman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 06-26-2013 01:53 PM |
| Carbign Craft Alternator Cover | BugeyedWagon | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 01-04-2013 10:58 AM |
| Alternator pulley?? | xpicer | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-13-2012 09:54 AM |
| Weak battery or bad alternator from factory? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-21-2012 03:17 PM |
