| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Drives: 2016 Scion FRS Halo
My car has been sitting out in the sun all day at this auto body shop for a couple weeks, and I'm worried that UV rays are going to damage my exterior paint and interior...Should I be concerned? How much does a car have to sit outside before it gets damaged significantly?
#2 |
Rust bucket enthusiast
Years. Years and years.
Not hours, days weeks. You're good
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#3 |
Drives: 2015 FR-S
Keep in mind that a large percentage of people dont have garages lol. Paint is built to handle all types of weather, including sun. Paint will fade over time but it takes years or decades for UV to do that
Sent from my SM-G975U using Tapatalk |
| The Following User Says Thank You to Itsthebeast For This Useful Post: | ghostzfh (05-16-2021) |
#4 |
The only thing is the dash might lift up from the vents area- which was a concern on earlier frs/BRZ.
I have a dashmat to help with that |
#5 |
Drives: Subaru BRZ
My car is a 2013 and has never been garaged. I live in Queensland Australia. The sun is BRUTAL! No damage to interior or exterior yet...
(Waxing is important) Sent from my SM-G973F using Tapatalk |
#6 |
Drives: 86 GT
The OEM windshield and windows has UV cutting so your interior will also be fine.
#7 |
If it is sitting at an body shop I think sunlight is the least of your worries!
| The Following 5 Users Say Thank You to Tcoat For This Useful Post: | brandonblt2 (05-21-2021), fitcious (05-17-2021), meWant (05-23-2021), soundman98 (05-17-2021), theneptune86 (05-17-2021) |
#8 |
Drives: 2013 Scion FR-S Series 10
I would somewhat worry about the interior if you are super anal. If the interior of your car is hitting 120+ degrees, all of the plastics and glues will be expanding and contracting. Things that were tight might suddenly be loose. Although the build quality of these cars being what they are, I'm not sure that it matters - nothing is screwed together all that well.
As for the exterior, I can't find the article right now but it talked about how paints are developed and tested against the sun so the paint doesn't fade. If I recall correctly, this company has car panels that sit out in the sun for decades to show that modern paints are not affected by UV rays or heat enough that you would notice. What gets people is pollutants embedded in the clearcoat and oxidation making the paint look hazy or discolored. So it's the clearcoat that is the issue, not the paint. A good buff and polish usually fixes that right up. If you have taken care of your paint, a few weeks isn't going to hurt anything. If you have a layer of wax, then a normal wash should clean it up just fine. |
#9 | |
ProCrastinationConsultant
and at that point, you're going to have much more significant problems considering that a car you're paying insurance, registration, and someone to work on it isn't being worked on! even in the worst conditions, i don't expect that there should be any noticeable damage for at least 5 years.
#10 | |
#11 |
Drives: 2013 FR-S Series 10
OP get a sunshade and stop worrying about it. Covercraft has a good one for like 50 bucks. Custom fit.
I apply 303 Protectant every once in a while too to the dash and other plastics.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers Corsa Catback Edelbrock Supercharger installed @ 50k |
| The Following User Says Thank You to Decep For This Useful Post: | Tcoat (05-20-2021) |
#12 | |
Certified Wumbologist
Drives: 2015 Scion FR-S
You can also find some on Amazon for even cheaper. Didn't have one for the first year or 2. Once I started to notice the dash lifting a bit near the vents, as stated by others, I got one asap. It also would help protect your other interior trims such as the top of your steering wheel.
| The Following User Says Thank You to KMA KiCKz For This Useful Post: | Tcoat (05-20-2021) |
#13 | ||
Oh and my FRS dash lifted in the middle of winter. It was a manufacturing or design issue as much as a heat or sun one.
| The Following User Says Thank You to Tcoat For This Useful Post: | KMA KiCKz (05-20-2021) |
#14 |
It is not 1955 and the paints haven't been a straight gloss enamel for at least 40 years. They are fine in the sun and weather. They are designed to be in the sun and weather. They take a far far worse beating from simply driving them than they do sitting outside.
| Tags |
| damage, maintenance, sunlight |
| interior led and exterior LED upgrades | DoubleAKash | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-18-2022 06:19 AM |
| Wtb: exterior and interior parts | Dave08 | Want-To-Buy Requests | 0 | 03-25-2014 01:06 AM |
| Interior and exterior lights | Jonoraven93 | Southeast | 5 | 07-20-2013 11:54 PM |
| BRZ interior or FRS exterior? | Latiii | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 06-20-2012 11:46 PM |
