Old 03-10-2021, 12:05 PM   #1
norcalXninja
norcalXninja's Avatar
Drives: 2013 Scion FR-S/2018 Tacoma
Techstream Issues
Hello. I recently picked up a 13 FRS. I already have techstream and an OBD cable that I used to make some changes in my Tacoma. I was hoping to modify some things on the FRS, everything seems to show up but when I go to adjust parameters nothing seems to show in the pop up windows. Upon further inspection it seems that there’s communication issues with the ECU. Any recommendations? Thanks in advance.
norcalXninja is offline   Reply With Quote
Old 03-10-2021, 12:48 PM   #2
ls1ac
ls1ac's Avatar
Check the Techstream version, I had a problem and found i had to find the right version.
Old 03-10-2021, 12:55 PM   #3
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Make sure the OBD port female pins are secure and tight against the male pins of the the tool. There are issues with the OBD ports in these cars. Experienced this with mine. You can use a pick tool to push the female pins in so they're tighter against the male pins.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 03-10-2021, 03:20 PM   #4
norcalXninja
Any chance you know which version? The one I got I found on the Tacoma forums. It was basically a cracked version opened with a key generator and has to be run offline in order for it to function lol. Works fine on the Tacoma but yea no go so far on the FRS
Old 03-10-2021, 05:51 PM   #5
ls1ac
ls1ac's Avatar
No idea what version, several years ago.
I had a problem with the OBD and got a Y splitter and it worked great. The reason for the Y was it was cheaper than an extender cable.
Old 03-10-2021, 06:12 PM   #6
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
I recently had to set this up again and wound up using version 15.00.027 on an old Toughbook running Windows 7 32-bit. Pretty sure this is the one:
https://www.blog-teknisi.com/2020/06...ation-key.html
...there's separate links for the installer, drivers, and loader.
BRZyJ is offline   Reply With Quote
Old 03-10-2021, 07:19 PM   #7
norcalXninja
Thank you! I’ll check what version I have then give this a shot
Old 05-26-2021, 10:27 AM   #8
Locost7
Drives: 15 86
Thx, I’ll try it out!
Locost7 is offline   Reply With Quote
Techstream TPMS registration issues M0nk3y Electronics | Audio | NAV | Infotainment 4 12-12-2023 02:35 AM
Toyota Techstream xjohnx Engine, Exhaust, Transmission 206 08-20-2023 05:01 PM
BRZ Techstream Xproplayer BRZ First-Gen (2012+) — General Topics 1 01-15-2019 09:33 PM
Techstream/ECU customizations phanguy Northern California 60 10-06-2013 12:12 AM
techstream spitfire481 Mid-Atlantic 0 09-14-2013 10:37 PM
