| Software Tuning Discuss all software tuning topics. |
Drives: Subaru BRZ MY16
MAF Reading 131008 g/s
Hello,
Has anyone ever had an issue or something similar with this? https://datazap.me/u/almondchassis/t...26-31-34-35-43 I'm currently getting a Flex Fuel tune via Ecutek and the car just stalls on start up reading 131008 g/s on the MAF Log. Says 14.7AFR but I can tell it's super rich with the smell of fuel. The car would idle fine with Stock Tune, as well as OFT Stage 2 that I've had on the car for about 6 months. Weirdly, when reflashing back to stock, then back to the same tune causing the issues, It would idle normally but happens again after I restart the car. The car also idles normally when I pull out the connection to the MAF sensor. (Using Stock MAF Housing just with Panel Filter and Mishimoto Inlet tube that shouldn't be causing the issue) Any ideas to what can be causing the issue or if anyone had something like this happen to them? I got a revised tune that seemed to fix it, but afterwards, on a cold start I get the same issue. I won't be able to talk to the tuner until a couple of days so just wanted to see if anyone experienced this before. |
#2 |
Drives: brz 2017 hksv2
Which map sensor do you have ?
I faced something similar activating the Speed density but using a stock map sensor on some of my recent remap It fixed by using a 3bar map it's probably due to Auto rom F20Q , i bet it has some kind of bug (not rare with latest racerom versions) ask delicious to try disabling speed density totally, or to force downgrade to an older Auto rom of the I serie Or to try an older racerom like 11.1... but i just think somehow the speed density is bugged in your case |
| The Following User Says Thank You to tomm.brz For This Useful Post: | AlmondChassis (04-25-2021) |
#3 | |
I'll let Delicious know about the SD if that could be causing the issue.
| The Following User Says Thank You to AlmondChassis For This Useful Post: | Carsnguitars (04-28-2021) |
#4 |
it's that 100%
It will fix with a different sensor like 3bar, but you can keep stock sensor and he can keep using latest racerom 12.1 but ask him to only use maf Even if he enable hybrid speed density but actually use only maf, it will cause the bug Now the switch to total maf will throw off his tune work )) He would need some revisions at least, to make a good job Just for your info, I think they use speed density because they set the curve the same for each car, so they have same engine load in each car and don't have to retune much. They let the ecu correct the AFR mainly Last edited by tomm.brz; 04-25-2021 at 03:44 AM. |
#5 | |
#6 |
#7 |
Drives: FT86
Yeah agree bunch of bugs in racerom 10/11 especially on auto and on USA roms, European roms seem much better
Tom also noticed that racerom 11/12 the SD seems 10% off entire VE table its weird same tune on RR10 ok but on RR11/12 the SD is 10% off shown by 10% closed loop correction , adjist SD by 10% then ok but only happens rr11/12 |
| The Following 2 Users Say Thank You to steve99 For This Useful Post: | AlmondChassis (04-25-2021), tomm.brz (04-25-2021) |
#8 |
Hey Guys,
So RR11.1 seemed to fix the issue with the MAF bug. The fuel trim seems pretty off though https://datazap.me/u/almondchassis/3...33-34-38-45-46 It sits at around -16% / -12% and the car even stalled when slowing down going down a driveway. From what I know negative fuel trims are most likely MAF scaling? I've reverted to stock flash and the Fuel Trim would be around -3% which is fine considering the ecu just got reflashed. Also noticed the rpm jerk when applying throttle, the log you can see the ignition timing completely drop. Would this all be a cause of MAF scaling issues? It's a stock airbox, just a Mishimoto Inlet tube and a drop in filter which I've run for a year just fine on stock/oft tune. |
#9 |
well I expected that, always good to have some confirmations
the fuel trims actually are a bit positive, there is also the CL fuel control He needs either to turn off ltft in open loop, or disable CL fuel control, and do a proper airflow scaling That would be enough for me to run away from the tuner , he doesn't know how Racerom works and he hasn't read the instruction that ecutek provided,i wouldn't want to pay someone that doesn't know how to properly tune this car, or is lazy. Because the few good tuners around for this know how to make it work in a proficue way This tune as it is made, will somewhat work on many different cars and will provide decent afr and low detonation, still i find it a shit-tune Just when I hear that an engine stalls on overrun or at idle it triggers me, sorry for the rant |
#10 | |
#11 |
yes I think he is the one.... With Zach the logs were sooo much different
)))that a OTS Hybrid SD based tune... he flashes this kind of tune to every guy that has similar (i bet also not very same headers also..) config like you... from the SD he gets an identical engine load curve for every car almost, so he doesn't "waste" time ( remember that you PAY for this time ) adjusting the timings and the airflow calculation... he just let both Subaru oem logic and ecutek closed loop adjust everything... only minimal modification are required from him to let the engine run safe The freak part is , he s having the closed loop systems fighting to each other I bet your car is quite unsmooth to drive |
#12 | |
Maybe I should take it local and get a dynotune, sucks because money spent on a headache at this point |
#13 |
Drives: FT86
There is a corruption in the base ecutek ZA1JF20Q rom file, the idle tables specifily idle target #1 the values are way low like 250 rpm idle, if that corruption has been copied accross to the tuners tune then it will cause you stalling issues
| Need Help Reading ECU | Eddy98 | Software Tuning | 1 | 12-21-2020 04:59 AM |
| OFT not reading ECU | Gray Fox | Software Tuning | 12 | 08-02-2017 07:44 PM |
| OFT not reading | 904FRSlow | Software Tuning | 34 | 11-04-2014 07:40 PM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 02:26 PM |
