Old 03-26-2017, 07:23 PM   #1
gmanvilla1@gmail.com
gmanvilla1@gmail.com's Avatar
Drives: FRS
Trunk won't open
My trunk won't open from the inside or even the remote control. I checked all the fuses and can't find any burned.
gmanvilla1@gmail.com is offline   Reply With Quote
Old 03-26-2017, 07:32 PM   #2
Creole
Creole's Avatar
Drives: Monogram FRS
If you have a push to start, take the key out of the key fob and put pop it open manually. Theres a button you can press on the inside of your trunk to allow the key fob button to work as well as the button inside the vehicle.
Build Thread:
Creoles Creation
Creole is offline   Reply With Quote
Old 03-26-2017, 07:32 PM   #3
swarb
Use the key?
There is a button inside the trunk to disable the dash button.
Old 03-26-2017, 07:34 PM   #4
byun
byun's Avatar
Drives: 2015 BRZ CWP
If it's not the button being switched. Check the fuse for the door locks. My car happened to blow that fuse which caused my trunk not to work.
byun is offline   Reply With Quote
Old 03-26-2017, 07:45 PM   #5
Drives: FRS
Got it. Thanks guys!!
The Following 3 Users Say Thank You to gmanvilla1@gmail.com For This Useful Post:
Jmonty (03-28-2017), JoeC (03-28-2017), Wally86 (10-19-2022)
Old 03-28-2017, 03:57 PM   #6
Jmonty
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
what was it?
Jmonty is offline   Reply With Quote
The Following User Says Thank You to Jmonty For This Useful Post:
JoeC (03-28-2017)
Old 03-28-2017, 05:22 PM   #7
Jmonty
if it is a fuse would the door locks still work?
Old 03-28-2017, 05:49 PM   #8
Drives: FRS
Originally Posted by Jmonty View Post
what was it?
I didn't even know that bottom was there..it probably got pressed by junk moving in the trunk.
The Following 2 Users Say Thank You to gmanvilla1@gmail.com For This Useful Post:
Jmonty (03-28-2017), Wally86 (10-19-2022)
Old 03-28-2017, 06:20 PM   #9
Jmonty
Yep, that little button in the truck
Old 03-28-2017, 08:52 PM   #10
OR ...... clean the junk out of the trunk.
Old 03-28-2017, 08:55 PM   #11
Yep that little button in the truck
Oh, I hope the grammar police don't see that ........
Old 03-29-2017, 03:30 PM   #12
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I think that's mainly a spelling mistake.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Old 03-29-2017, 03:36 PM   #13
..... pay attention, the OP edited his post.
Besides, who banged on your dog house ..??
Old 10-15-2022, 02:03 AM   #14
PopaNolie
Drives: Scion FR-S
What fuse did you replace?
For me it turned out the wire from the driver side internal harness ripped off because of some cheap old audio system the previous owner mickey moused.
PopaNolie is offline   Reply With Quote
Trunk won't pop open Reflex Issues | Warranty | Recalls / TSB 36 01-02-2021 04:16 PM
Trunk will not open Hbomb Issues | Warranty | Recalls / TSB 33 06-12-2017 07:56 AM
Trunk Won't Open with Either Key Fob or Dash Trunk Release Ehokana Issues | Warranty | Recalls / TSB 15 04-08-2017 04:22 PM
Trunk will not open BAE Issues | Warranty | Recalls / TSB 14 06-04-2013 05:21 PM
Trunk won't open Sparda29 Issues | Warranty | Recalls / TSB 13 01-11-2013 12:10 PM
