Old 12-20-2020, 10:37 PM   #1
dholloway543
Software Hobbiest
Drives: 2015 FRS
high fuel trims
Back 3 months ago I zeroed out all of my fuel trims buy adjusting the MAF sensor and they stayed zero. Now 3 months later I have all positive fuel trims some up to 9%. The only thing that has changed is the air filter and the temperature. Do you think that could be the variable that changed or is it a sign of something else.
Ex. the combined fuel trim at 600rpm 0.15 engine load is at +8.1%
dholloway543 is offline   Reply With Quote
Old 12-20-2020, 10:46 PM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
What tune are you using?
Old 12-20-2020, 10:54 PM   #3
dholloway543
Software Hobbiest
Drives: 2015 FRS
A custom tune made for a my specific turboed car
Old 12-21-2020, 04:57 AM   #4
steve99
Drives: FT86
fuel trims at idle can vary quote a bit with large variations in intake air temperature.
Add 4% to maf scale in that low end area then 2% to thexarea jist above to smooth it in
dholloway543 (12-22-2020)
Possible vacuum leak? (Running lean and high fuel trims) nickw14 Engine, Exhaust, Transmission 6 02-10-2023 11:56 AM
Help needed please, High negative short term fuel trims Kris86 Issues | Warranty | Recalls / TSB 11 11-26-2020 06:39 AM
What would make fuel trims high when engine is cold but OK after warmed up? kev0 Issues | Warranty | Recalls / TSB 11 01-06-2020 03:44 PM
short term fuel trims high at idle and and partial throttle Minidude147 Software Tuning 5 03-28-2019 06:53 AM
Sudden high fuel trims - help please! cawith Issues | Warranty | Recalls / TSB 13 10-15-2015 05:30 PM
