| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2014 FRS
Has anyone ever had to use them? I know that there are detergents in the oil and gas, contemplating using it as cheap insurance. Any opinions would be great! thank you
| The Following User Says Thank You to 1234eher For This Useful Post: | humfrz (08-13-2020) |
#2 |
Rust bucket enthusiast
Insurance against what? What are you afraid is in the engine that shouldn't be?
You need to know what problem you're trying to solve before you start trying to fix it, it'll help a lot in guiding yourself towards the right answer |
#3 |
Use good gasoline and change you oil often. No need for this BS.
#4 |
#5 |
No need, even ones that increase mpg like Lucas fuel treatment (I have tested it and can get 1-2 mpg more), the added cost evens out the with the added mileage. So no real savings.
#6 |
The Dictater
Drives: '13 Red Scion FRS
+1 not needed
#7 |
Drives: 2020 Subaru BRZ TS
Same here, never used those on any of my vehicles. I did however use the odd seafoam treatment once in a while when some of my cars started to show signs of age just to restore gas mileage and clean up internals.
#8 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
I put a couple teaspoons of Seafoam in the tank of my 2stroke weed whacker, but only the first time I start it up for the season.
Works for carbureted engines. Mostly useless for fuel injection.
"I gotta rock." -- Charley Brown |
#9 |
Drives: 2014 MY15 86 GTS
I’ve used oil flush just because the dealership I bought it off used shit oil.
| Tags |
| flush, fuel system, gas, maintanence, oil |
| Does running e85 keep the engine cleaner? | pcguru2000 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 08-18-2018 01:36 PM |
| Fuel system questions. Boost-A-pump/stock fuel lines for engine swap | Toxicmilk45 | Engine, Exhaust, Transmission | 4 | 12-14-2015 04:52 PM |
| Lucas Fuel Injector Cleaner Discoloration | Eski | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 0 | 02-03-2015 01:57 PM |
| Crickets be gone! lucas oil deep clean fuel system cleaner | SliverBrz | Issues | Warranty | Recalls / TSB | 15 | 09-23-2013 09:22 PM |
| Fuel Injector Cleaner | Purdue FR-S | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-18-2013 07:54 AM |
