Overpipe with sway bar clearance?
Wondering if anyone can confirm running any of these over pipe options with a larger front sway bar? I'm running a 25.4mm Hotchkis front sway bar.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
I'd like an accurate answer to this as well, but it seems like nearly every aftermarket overpipe has clearance issues with the subframe and/or bigger sways without stiffer engine mounts or grinding down the subframe to allow clearance under load.
Stock overpipe seems like the best bet for a while until the aftermarket figures out how to make them with clearance considering drivetrain movement under load with the stock mounts. |
#3 |
Drives: 2013 SWP BRZ
Isn't there minimal gains anyways with an overpipe? I'm doing the same though, leaving the stock overpipe and changing everything else.
#4 |
Drives: WRB BRZ
I have the Hotchkis bar and the overpipe (Motiv) hits the swaybar. I had to use some wide washers to lower the swaybar mounts down slightly to clear. No issues so far.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
| The Following 2 Users Say Thank You to chutrain For This Useful Post: | swift996 (07-25-2013), Tim_Asphalt_FRS (07-25-2013) |
#5 |
Drives: 13 Whiteout
Subbed for no fuss overpipe info.
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#6 |
Drives: 2013 FRS
I have the cusco sway bar. Wonder if there will be issues there. Any input? Planning on getting the Perrin overpipe
#7 |
Drives: 2013 FRS
Do overpipes usually have an issue?
#8 |
Drives: Ultramarine FR-S (MT)
Nameless over/frontpipe combo with Hotchkis front and rear Sway bars
It's hard to tell if it's just the road or the overpipe hitting. So far, if it does, it's not frequent enough but i'll have to check.
| The Following User Says Thank You to Books For This Useful Post: | ft86me (07-25-2013) |
#9 |
Drives: White FR-S, 6M
I'm running the hotchkis sway bar kit and motiv overpipe with plenty of clearance.
EDIT: the more I think about it... I have a slight raspiness/vibration under load sometimes that may in fact be the overpipe hitting but I had this before the hotchkis sway bar as well. I need to get back under the car and take a look. I'm going to look into it further and see if there is a suitable place for a torque strap.
| The Following 2 Users Say Thank You to FastLane1000 For This Useful Post: | ft86me (07-25-2013), Tim_Asphalt_FRS (07-25-2013) |
#10 |
Drives: WRB BRZ
Mine was definitely the overpipe hitting the sway bar. I could see some of the paint missing on the swaybar and small mark on the overpipe. I only really hear it when it I give it a good takeoff in first or hard run in second, but it still annoyed me.
I had contacted Motiv and they mentioned that they only tested with the factory swaybar and not with a thicker aftermarket. I suspect that most companies did not test with a thicker aftermarket bar, therefore could be a hit or miss for many.
In the garage:
| The Following User Says Thank You to chutrain For This Useful Post: | ft86me (07-25-2013) |
#11 |
Drives: WRB BRZ
Motiv does great work with their products, so I do not fault them. Everything bolted up nicely. It could be variances in the cars themselves, something that I have seen before. I had maybe less than a quarter of an inch between bar and pipe.
In the garage:
#12 |
Yeah most of these parts are designed with everything stock in mind. I've ran into quite a few snags where a design didn't have other aftermarket parts factored in. The product of such a new platform!
#13 |
Anyone running a Perin over-pipe?
#14 |
Drives: 2013 Scion FR-S MT
Nameless OP/DP combo here reporting no issues what so ever.
| Wheel Directory: Forgestar F14 18x9.5 +38 | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 12-26-2014 05:24 AM |
| Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! | MotivConcepts | Engine, Exhaust, Bolt-Ons | 96 | 07-19-2013 02:03 AM |
| Body Kit with the most clearance? | Sambo FRS | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 06-20-2013 01:47 PM |
| Driveway Clearance? | topazsparrow | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 06-14-2013 11:37 AM |
| BRZ front clearance | a2cpc | BRZ First-Gen (2012+) — General Topics | 14 | 01-23-2013 07:38 AM |
