Drives: 2013 Scion FRS
Sudden MPG drop
I bought my FRS in 2013 and for the first few years I was happy getting ~23 mpg almost all city driving. I calculated it myself after every refuel. One day it dropped to ~18 and has been the same ever since. After a couple years of this, I took it to the dealer and they used a scan tool and said everything was in range. I just fueled up yesterday and got 17 MPG on this tank and it's driving me crazy.
Is there an issue that wouldn't show up on the scan tool or something I should look into to figure this out? Tires are aired to specs. I've gotten all recommended maintenance. Driving habits haven't changed. Thanks for any suggestions. |
#2 |
Has the intake air temperature (IAT) sensor been cleaned? Also, when was the last time the engine air filter was replaced? Finally, have you switched to a lower octane fuel?
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
#3 |
Rust bucket enthusiast
Maybe the traffic in where you're driving has changed significantly. Could be that you accidentally switched to kilometers instead of miles on your odometer.
Could be a culmination of things- low air pressure in the tires, super dirty air filter, along with the oil needing to be changed and your rear passenger side brake caliper dragging just a bit. Or you are suddenly worse at math |
#4 |
Senior Citizen Member
Drives: Then-1977 Celica GT Now-2017 860SE
How many miles on the odometer?
Time for new spark plugs? |
#5 | ||
Lmao it's hard to routinely mess up miles/gallons, but I'll start double checking. 46k miles on the odometer. Spark plugs were changed a year ago. Thank you all for responding |
#6 |
Change your air filter! It's cheap, easy, and fun. If that doesn't fix it, spark plugs. You may also want to try bottle of fuel injector cleaner.
Sent from my SM-G975U using Tapatalk |
#7 | |
#8 |
Drives: GR86 Trueno Edition
Was the ~23 mpg same during winter and summer ?
I have a noticeable change between summer and winter. Did you check every fueling or from time to time. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to Busybee For This Useful Post: | p1l0t (06-05-2020) |
#9 |
There is a definite difference between winter and summer blend fuel. Here is the average by month for the history of my car. The dips occur consistently in the winter but 90% of my driving is the exact same route. That does not change per month.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#10 |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tcoat (06-05-2020) |
#11 | |
Looks like your average increased from 2013 to 2020. What was the change in 2019 and 2020 increasing the overall average ? Looks very nice ![]() Sent from my iPhone using Tapatalk |
#12 |
#13 | |
The tires have been changed twice (I'm on my third set) but sets one and two are the same tires (see my owner's journal for details). I expected it eventually to peak as the car went from stiff to running to aging state but so far at over 160K miles, that hasn't happened. Driving habits haven't changed either, and as mentioned above, since this is my commuter (80 mile around trip per day) nearly all the miles are on the same road, and same time of day. There is only the occasional road trip. On weekends I drive a different car most the time.
#14 |
Actually I don't. I'm first off the line (never been beat by a soccer mom), take most curves at twice the "recommended speed" and drive manual a good bit of the time.
The secret is my average speed falls right into the sweet spot of around 50MPH.
| The Following 3 Users Say Thank You to Dadhawk For This Useful Post: |
| Sudden lean 17AFR, but then sudden rich 10AFR??? No codes | D-VO | Software Tuning | 4 | 12-11-2019 01:17 AM |
| Sudden Power Loss / Hesitation and jerking under WOT | Jesse36m3 | Forced Induction | 6 | 05-14-2018 10:59 PM |
| Sudden limp shifter feel. | MWD | Issues | Warranty | Recalls / TSB | 6 | 11-06-2017 11:38 AM |
| about the car's sudden change in idling | gustavowoltmann | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 10-19-2016 06:30 AM |
| Sudden high fuel trims - help please! | cawith | Issues | Warranty | Recalls / TSB | 13 | 10-15-2015 05:30 PM |
