Old 05-18-2020, 10:21 AM   #1
ThatYeti
'17+ stock headers vs aftermarket catted headers
Doing some searching and not seeing much consensus as to whether there's any real benefit to adding a header (if it's going to be catted) in place of the stock '17+ header as apparently they were opened up in the refresh.
Looking for a small bump in power, and to be able to run OFT stage 2, but not sure if adding a header is going to be any better than stock in this case.
(only considering catted header as I'm not looking to run into any emissions testing issues)
Thanks in advance for any help on this.
ThatYeti is offline   Reply With Quote
Old 05-18-2020, 10:32 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
From my (limited) understanding, the real gain in flattening the torque dip (and a mild boost in overall power) is from removing the cat, not from the tune alone. So I would guess that a catted header wouldn't provide as much benefit as a catless header (or maybe none at all for 2017+).
Old 05-18-2020, 10:59 AM   #3
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A good aftermarket catted header would have a small advantage, because it is using a sport cat. Meaning a cat will less cells.
Old 05-18-2020, 11:00 AM   #4
Lantanafrs2
Drives: 2013 frs red
Probably no real advantage with an aftermarket catted header. Catless would help. Tune it and enjoy it. Keep it clean and as stock as possible so you can move it when you want a faster car.
Lantanafrs2 is offline   Reply With Quote
Old 05-18-2020, 11:11 AM   #5
ThatYeti
Ok, but given there's little difference between the stock '17+ cat and an aftermarket one, would I be ok to move to OFT stage 2 with what i've got stock?
Old 05-18-2020, 11:12 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Honestly if you want to stay catted on a facelift car, get a flex fuel tune and run E85. torque dip will be gone.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Goingnowherefast (05-20-2020), mrg666 (05-21-2020), Ohio Enthusiast (05-18-2020)
Old 05-18-2020, 11:17 AM   #7
ThatYeti
Love to.....but the nearest E85 station is 90 mins away....
The Following User Says Thank You to ThatYeti For This Useful Post:
Yoshoobaroo (05-18-2020)
Old 05-18-2020, 12:45 PM   #8
Yoshoobaroo
TRACKBREAD
that's just a small detour on you're way home!
Old 05-18-2020, 03:27 PM   #9
Ernest72
Go drive someone’s 13-16 twin with a catless header and compare to your car. Only way you will really know.
My 16 is jdl catless header, jdl FP catted and resonated, drop in filter and Crawford powrblocks with OFT stage 2 plus tune. It is significantly better than stock, but nothing like the bump going to stage 2 on my WRX. Still worth it.
Old 05-18-2020, 03:44 PM   #10
ThatYeti
Appreciate that I guess....cept the whole 'rona thing....And not sure I'd compare a BRZ/86 to a WRX....very different cars
Old 05-20-2020, 05:14 PM   #11
Ernest72
I agree just saying the benefits for NA are small things that add up. Compared to the WRX where changes are more dramatic being a turbo.
Old 05-21-2020, 02:13 AM   #12
jflogerzi
jflogerzi's Avatar
Not worth it. Only reason if you wanted uel for a different sound.
2013 Series 10 FRS #553
Old 05-21-2020, 07:59 AM   #13
Yoshoobaroo
TRACKBREAD
I'm firmly in this camp now too. Once you learn to drive around the torque dip, it's a non-issue. I went from stock > UEL > UEL+FP > UEL+FP+E85 > Stock header/fp + catback. The catback was worth it for the sound. Everything else, even the E85 didn't make a great difference in the higher rev ranges, not for the money spent at least.
Old 05-21-2020, 08:26 AM   #14
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You will get some power, but sound should be the main goal for that setup.
It allows you to run pretty much any catback without being obnoxiously loud.
Catted Headers EN2_Squirrel Engine, Exhaust, Transmission 53 12-16-2016 10:52 PM
WTB UEL Catted Headers LastRep Canada Classifieds 0 08-08-2016 12:51 PM
WTB catted uel headers Legionsk88 Want-To-Buy Requests 0 04-21-2016 08:48 PM
OFT with Catted headers DarkestBuddha Software Tuning 6 10-14-2014 11:51 AM
P&L Catted headers and Nameless catted Front pipe. Also is this cricket noise? Xdragonxb0i Engine, Exhaust, Transmission 23 04-24-2013 01:29 PM
