Old 04-27-2020, 12:18 PM   #1
imprezive
Drives: 2017 BRZ - WRB - PP
"Stage 2" bolt-ons worth it?
Daily driver + occasional AutoX + potential very occasional track day (for fun, so probably would only push car to 95% and intersperse some 75%/cool down laps)
Currently have JDL UEL + K&N drop-in + Perrin Intake Tube + Fujitsubo Authorize S Axle back + OTS tune.
Feeling itchy for just a little more HP (maybe 10-15), but my understanding is there isn't much more I can do in the way of bolt-ons to squeeze out some more HP.
I used to own an 2000 Impreza 2.5RS and had ALL the "bolt-ons", plus lightened flywheel, pulleys, cams. Although, the pulleys/flywheel didn't actually add HP, it did make the car more lively/responsive.
I've considered going FI. I can afford it, per se, but not sure I want the potential headaches. I prefer to have a reliable daily-driver vs a "tuner car" that I'm always fiddling with to keep in on the road.
Are there any other non-internal mods I missing that could help me squeeze out a few more HP?
There isn't a lot of E85 in my area...but maybe a flex fuel kit?
Maybe just pulleys, over-pipe, mid-pipe, and custom tune would be enough to deliver a little more pep?
I realize now that this is mostly rambling, I try to edit it later. In the meantime, feel free to share any insights.
imprezive is offline   Reply With Quote
Old 04-27-2020, 12:22 PM   #2
Ashikabi
Ashikabi's Avatar
You're going to spend a fortune and not really make much more. 10hp won't be noticeable in my opinion. Might as well boost it. For the same cost at least you'll make good power
Sent from my ONEPLUS A5010 using Tapatalk
The Following User Says Thank You to Ashikabi For This Useful Post:
imprezive (04-27-2020)
Old 04-27-2020, 12:24 PM   #3
Joveen
Joveen's Avatar
Drives: Bone stock
Header and E85 is all you need. I learnt the hard way. Only thing worth it power wise on this car is boost. I didnt notice the torque dip that people mentioned when my car was stock. I just thought it was slow. Even with stage 2+ it's still slow.
If you want easy bolt on boost go Supercharger. If you want more head room for power and more torque go turbo. JDL Turbski is what I recommend as it is what I'm saving for.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
The Following 3 Users Say Thank You to Joveen For This Useful Post:
imprezive (04-27-2020), kevaughan (05-05-2020), why? (04-28-2020)
Old 04-27-2020, 12:52 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I second the nod at getting a supercharger. I have been in a car that has the Sprintex/Innovate 210 supercharger. It's cheap, and the car pulls really nicely., He hasn't had a single issue with it yet in the past 2 years. Best thing? He has stock clutch and fuel mods. He can also take it off in a matter of an hour or two.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
imprezive (04-27-2020), Joveen (04-27-2020)
Old 04-27-2020, 01:14 PM   #5
ls1ac
ls1ac's Avatar
I too have the 210, but fun of driving came from GOOD tires. No drifting but great turns. You have a tune, turn off the nannies and hold on.
I know they are expensive but I use AD08s or their current name. And yes they do work in the rain.
Old 04-27-2020, 01:16 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yes.
Old 04-27-2020, 01:48 PM   #7
Lantanafrs2
Drives: 2013 frs red
Custom tune might give you another 5 horsepower if you're lucky. If you're tracking the car, I would think twice before going the forced induction route. Too many tales of woe for me.
Lantanafrs2 is online now   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Old 04-27-2020, 02:15 PM   #8
86TOYO2k17
Drives: 2017 toyota 86
I did the full blown NA route throwing tons of money for minimal gains doing basically everything short of opening the engine. It was a fun experience but never enough. I have a sprintex 210 now, its a blast, I don’t necessarily regret my decisions I’ve taken for my car build for various reasons.
But in hindsight. I would probably have gone straight to a small quick spooling 9psi turbo from the beginning. Best bang for buck and reliability. That plus Oil cooler, catch can, hood vents, and wheels/tires.
Old 04-27-2020, 04:34 PM   #9
NV89
NV89's Avatar
Drives: 14 BRZ, Genesis coupe track, 05 sti
I got rid of my car sure to weak tranny after dropping too much into it. If you want reliable power... Don't boost or get a different tranny
Sent from my Pixel 3 using Tapatalk
NV89 is offline   Reply With Quote
Old 04-27-2020, 05:17 PM   #10
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Where you're at, the next best bang for your buck would be a supercharger. That just entails deciding which one you want.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Old 04-27-2020, 06:00 PM   #11
imprezive
Yeah, or just learn to be happy with more reliability and spend the $5k on something else.
Old 04-27-2020, 06:25 PM   #12
86TOYO2k17
Out of boost it’s really not much less reliable or different. If you are tracking the car it’s obviously a lot different, but for a DD only car, you do a few pulls here and there for 5-10seconds hitting boost, but mostly just cruising. Its fun having the power when you want and as long as setup properly and don’t get greedy on boost, its not really that much more unreliable.
As far as staying NA goes.
WMI
Grimmspeed CAI
Billet power blocks
Ace header 250 header
Catless frontpipe
Custom tune
Lightweight flywheel
Under-driven water/alt pulleys
Fluidampr crank pulley
Other weight reduction like shorai battery, remove trunk junk, rear seat delete, carbon fiber driveshaft, willwood 4pot bbk, lightweight wheels, lightweight seats.
Drag reduction Aero like front lip, front wheel deflectors, full under-panels, rear diffuser, rear spats, side skirt, rear spoiler, trd fender fins, trd side stabilizer, trd trunk stabilizer, trd aero turbulator,
More aggressive gearing with a 4.56FD swap
That will pretty much max out your power/straight line performance if staying NA. Its a small fortune for little return, ask me how i know...But It does all add up and make a difference, and doesn’t hurt reliability.
The Following 4 Users Say Thank You to 86TOYO2k17 For This Useful Post:
airrick (04-27-2020), kevaughan (05-05-2020), SuperTom (04-28-2020), why? (04-28-2020)
Old 04-27-2020, 06:54 PM   #13
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I don't think 5-10 HP is going to give you any more noticeable power than what you've already got. UEL + Tune already gives the car the kick/pep that people crave. A bump on top of that is just icing. e85/Flex Fuel is going to be the next contribution you're going to really feel in the butt dyno on NA.
From there, it comes down to how much do you want to spend. Do you just want to invest a little more to close-out the missing bolt-on options? Or do you want spend big bucks to chase the last 5% of what's possible on a reasonable NA set-up (e.g. buying the best/premium components, dyno tune, etc)?
Uncatted front pipe and Flex Fuel/e85 are probably the most accessible means to add the 10-15 HP you're looking for. Tack on a custom Ecutek remote tune to round up the package. Not the cheapest, but the most obvious and reasonable to max out the engine on NA bolt-ons.
If you want to increase responsiveness, you already know what's coming because you've been there. Lightweight rotating components, chassis reinforcements/stiffer bushings, etc.
EndlessAzure is offline   Reply With Quote
Old 04-27-2020, 07:20 PM   #14
imprezive
Originally Posted by 86TOYO2k17 View Post
WMI
I'm not familiar.
2017 BRZ "sti performance package" worth it? funeralpolis BRZ First-Gen (2012+) — General Topics 5 06-02-2017 01:05 PM
Perrin intake tube "worth it"? ANTLAY Engine, Exhaust, Transmission 60 10-11-2014 06:41 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
SUBARU 4Pot Calipers "Bremboed" Direct Bolt On- SD, CA CHEAP! virjose Brakes, Suspension, Chassis 32 07-12-2013 12:40 PM
May 2010 Car&Driver issue FT-86 article - "25 Cars Worth Waiting For" JDMinc Scion FR-S / Toyota 86 GT86 General Forum 76 04-17-2010 03:58 AM
