Old 04-26-2020, 12:10 PM   #1
alone1i
Not pro yet
Drives: 2020 Toyota GT86
Battery could die in 2 months for not driving?
Heya, my new 86 has only 400KM in it and parked inside garage. The problem is, I'm in overseas and can not go back to my country due to Corona-Situation. It is already 2 months now and I may need 1 more month to get back. How is the chances the battery will die? or any other problem I may face? Suggestion please.
alone1i is offline   Reply With Quote
Old 04-26-2020, 12:20 PM   #2
p1l0t
p1l0t's Avatar
Yes it will probably* die if you leave it plugged in to the car. I would recommend buying a battery tender they are inexpensive and increase the life of your battery. I keep one on my 74" Lincoln and it starts right up even if I let it sit for 2 or 3 weeks during the winter.
The Following 2 Users Say Thank You to p1l0t For This Useful Post:
AJ32162 (04-26-2020), alone1i (04-26-2020)
Old 04-26-2020, 12:23 PM   #3
Windycitystig
Drives:
Buy a battery tender and charge the battery before starting. Should be fine.
Windycitystig is offline   Reply With Quote
The Following 3 Users Say Thank You to Windycitystig For This Useful Post:
AJ32162 (04-26-2020), alone1i (04-26-2020), p1l0t (04-26-2020)
Old 04-26-2020, 12:35 PM   #4
Nice to say “ buy a tender” but the poor dude isn’t even in his country.
Yes it will probably die. There are a lot of systems that create a parasitic draw on modern cars. If the car is planned to be down for a prolonged period either get a tender or unhook the battery. An unhooked battery will hold a charge for a surprisingly long time.
For unplanned there is not much you can do but charge it up well when you get back.
Hope you get home soon!
alone1i (04-26-2020), gravitylover (04-27-2020), soundman98 (04-26-2020), Spuds (04-27-2020), why? (04-27-2020)
Old 04-26-2020, 12:42 PM   #5
p1l0t
p1l0t's Avatar
Have it shipped to a relative? Might not be a bad idea to have them start it and let it run for 20 minutes once a month.
alone1i (04-26-2020), Spuds (04-27-2020)
Old 04-26-2020, 12:42 PM   #6
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Yea, mine died when it sat for 1 month. Luckily battery was young enough at the time that it took a charge. Since yours is a 2020 model odds are it will take a charge when you get home. Good luck getting home.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
alone1i (04-26-2020), p1l0t (04-26-2020), Spuds (04-27-2020)
Old 04-26-2020, 12:44 PM   #7
ls1ac
ls1ac's Avatar
Maybe he has got a friend that can do it? Disconnect is the easiest tender is the best.
edit: It is probable dead at this point, and most tenders will not charge a dead battery. A knowledgeable friend might be able to first charge then put a tender and save the battery.
The Following 6 Users Say Thank You to ls1ac For This Useful Post:
AJ32162 (04-26-2020), alone1i (04-26-2020), p1l0t (04-26-2020), soundman98 (04-26-2020), Spuds (04-27-2020), ToySub1946 (04-26-2020)
Old 04-26-2020, 12:49 PM   #8
alone1i
Not pro yet
Thank you all. Is there any other problem may arise? I have heard that, brand new like cars should not be sitting for long. Bad for engine and transmission. Is it really applicable on my situation? Any precaution i should do once i reach home?
Also unfortunately i brought the key with me. Even in my home country kind of lockdown. No friends will be able help me i guess. But i have asked few, less chance i may get them.
Old 04-26-2020, 12:51 PM   #9
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Your tires will need air, charge battery, top off with fresh gas, and you should be fine.
The Following 5 Users Say Thank You to Sapphireho For This Useful Post:
alone1i (04-26-2020), Busybee (04-27-2020), Opie (04-27-2020), p1l0t (04-26-2020), Spuds (04-27-2020)
Old 04-26-2020, 01:20 PM   #10
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
It may be dead. It's no big deal. When you get back, put a jumper pack on it. After it starts, take it for a 20 minute drive and the alternator will charge it completely. Dead batteries are little more than an annoyance, don't let it worry you.
Good luck getting home, sounds like an awful situation
The Following 6 Users Say Thank You to DarkPira7e For This Useful Post:
alone1i (04-26-2020), Busybee (04-27-2020), humfrz (04-27-2020), soundman98 (04-26-2020), Spuds (04-27-2020), strat61caster (04-27-2020)
Old 04-26-2020, 01:25 PM   #11
New cars sit for months and months with no issues. As long as it isn’t parked in the middle of a field with the hood and gas cap open then it is fine. When you get back charge the battery before trying to start the car and then just take it easy for a couple of hundred miles.
All will be just fine.
alone1i (04-26-2020), Busybee (04-27-2020), soundman98 (04-26-2020), Spuds (04-27-2020)
Old 04-27-2020, 02:20 AM   #12
I think you slipped a cog on that one, there, DarkPira7e -
I reckon it's gonna take an alternator a heck of a lot longer than 20 minutes to bring a dead battery back up to full charge. Maybe several hours, if at all.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
alone1i (04-27-2020), gravitylover (04-27-2020), Opie (04-27-2020)
Old 04-27-2020, 08:29 AM   #13
BigHugeFatGuy
BigHugeFatGuy's Avatar
Drives: 2016 FRS
Yup. I hadn't driven mine since March 14th, until yesterday. Battery was at 10 volts. Slow charged and it started fine, then the tire light was on, as one tire was a 24 psi. Fixed that, it drove fine.
BigHugeFatGuy is offline   Reply With Quote
The Following 2 Users Say Thank You to BigHugeFatGuy For This Useful Post:
alone1i (04-27-2020), Tcoat (04-27-2020)
Old 04-27-2020, 09:54 AM   #14
Ernest72
Long term with ethanol in gas can cause some issues. But I think a few months you will fine. If you know it will sit in the future you could put a product Stable into the gas. Just deal with it when you get back. I am sure you will be stoked to be home, see your family and car and put this thing behind us. Good luck.
The Following User Says Thank You to Ernest72 For This Useful Post:
alone1i (04-29-2020)
Help please. maybe battery bad but shuts off while driving Nefarious Issues | Warranty | Recalls / TSB 13 03-20-2017 11:14 PM
10 months old - battery dead this am. Auto off headlights? Large Issues | Warranty | Recalls / TSB 10 05-28-2016 11:12 PM
Driving cross country in the next couple months rainmonkey BRZ First-Gen (2012+) — General Topics 24 02-17-2016 08:58 AM
How many days the battery last without driving the car? djmm Scion FR-S / Toyota 86 GT86 General Forum 35 04-02-2014 07:13 PM
Been a few months since driving my 350Z mike_ekim1024 FR-S / BRZ vs.... 15 11-29-2013 03:47 AM
