Old 02-18-2020, 01:25 PM   #1
degozaru
Drives: 2016 oceanic frs
Convert FF from sec O2 to evap
Hey guys,
I'm looking for a flex fuel that will work with the OFT because I'm a cheapo, but I was wondering if I could convert a sec O2 plug flex fuel kit to an evap input flex fuel. I read that the evap and o2 sensor port are both just inputs into the ECU. By that logic, it shouldn't matter which pin I input at, right?
I read that OFT flex fuel will only work with evap inputs.
Also, does Shiv give flex fuel tunes for free? Or is it an additional cost?
Thanks all!
degozaru is offline   Reply With Quote
Old 02-18-2020, 01:34 PM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Originally Posted by degozaru View Post
Hey guys,
You can convert the O2 kit to the EVAP kit but you do have to have it plugged in into the EVAP pin on the ECU (as it takes the volts from the evap pin to determine the flex fuel map changes)
Yes, only evap input for FF on OFT.
If it is the OFT FF, they do it for free. If not, then additional cost as I learned the hard way. You can also contact @steve99 to help you out as well.
Thanks all!
See in red.
Bach415 is offline   Reply With Quote
Old 02-18-2020, 01:46 PM   #3
degozaru
That was quick!
Thanks for your insight. If I have to buy a tune, I think it'll be cheaper to buy the OFT flex fuel kit new...
Thanks!
Old 02-18-2020, 02:01 PM   #4
degozaru
Originally Posted by Bach415 View Post
See in red.
I've sent you a pm asking for more information if you don't mind helping me out
Old 02-18-2020, 04:24 PM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
this wont help you pass inspection. you need evap to pass too
Old 02-18-2020, 04:51 PM   #6
Bach415
Bach415's Avatar
Iirc, according the ca dmv, as long as evap readiness is the only thing that failed, we should still pass (minus visuals as that depends on the tech).
Old 02-18-2020, 05:10 PM   #7
Breadman
Breadman's Avatar
well i stand corrected. i thought you needed all ready. i know in pa you can have 1 non ready as long as your CEL doesnt show
Old 02-19-2020, 12:50 PM   #8
Bach415
Bach415's Avatar
I thought so too until I did more research on the smogging requirements for CA. EVAP is the only thing that can fail. Don't know why (maybe its just gas vapors vs full on air emissions). But as long as that is true, I just got to find a better way to hide my FF sensor prior to smog (making it look oem rather than on top of the brake/abs module)
EVAP Line??? gtpvette Engine Swaps 12 09-18-2023 12:24 AM
Evap system repair johnmayqwerty Engine, Exhaust, Transmission 18 04-01-2019 02:43 PM
EVAP/CPC Solenoid Delete? BRX Issues | Warranty | Recalls / TSB 7 09-09-2017 08:52 PM
Evap readiness Brz_Joe Forced Induction 0 06-02-2017 02:09 PM
EVAP Solenoid Ryan P Forced Induction 0 06-25-2014 09:43 AM
