Old 01-12-2020, 10:44 PM   #1
Asphalt_15frs
Asphalt_15frs's Avatar
Drives: 2015 base frs
Exclamation Search of 10series/monogram output pics!
Well debating on if do a full retrofit(did one on my old car) or will 10series or monogram headlight be enough.
So anyone have 10 series/monogram night time pictures of their lights? On wall or just the light output. Thanks.
Asphalt_15frs is offline   Reply With Quote
Old 01-13-2020, 12:03 AM   #2
Jdmjunkie
Drives: Scion FR-S 10 Series
I don't have pictures, but my 10 series lights are some of the best stock headlights I have driven.
Jdmjunkie is offline   Reply With Quote
Old 01-14-2020, 03:35 PM   #3
mazeroni
Drives: 2013 Scion FR-S Series 10
No pics, but I agree that they produce a relatively even strong blue/ white light for 20-30 feet ahead with a strong cutoff. However, as you would expect, they fall off relatively quickly. I have so-so night vision, so maybe someone else has a different experience.
Can you retrofit the dial to adjust the height? I've been flashed because the person thought I had my brights on. That was with the dial set to 3. I believe the dial goes to 4 for the highest position? I normally try to keep it on 2 and just use brights when I'm alone on the road.
mazeroni is offline   Reply With Quote
10Series / Release Series / Monogram 6k HID Bulks gepeyo Exterior Parts (Aero, Lighting, Etc.) 0 12-31-2017 04:44 PM
WTB diode dynamics DRL module for release series 1.0/ 10series. Gregorio3 Want-To-Buy Requests 16 12-27-2015 02:49 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 06:31 PM
Are there bulb upgrades for the 10series HID headlights? Tenchi Cosmetic Modification (Interior/Exterior/Lighting) 6 03-14-2014 03:03 AM
