Old 01-12-2020, 12:14 AM   #1
jflogerzi
jflogerzi's Avatar
Best setup for fuel starveation and oil baffled pan
I am looking to complete in the full season of the 2020 season 86cup. The last 3 mods I need to complete my build is upgraded fuel pump/flapper mod and a baffled oil pan along with track spec hood vents.
For the first 2 what are the best mods to address this.
2013 Series 10 FRS #553
Old 01-12-2020, 12:21 AM   #2
whataboutbob
AutoX-10/10ths every run
I'd vote:
1) Fuel
2) Oil
3) Vents
Build thread:Here
Old 01-12-2020, 12:24 AM   #3
jflogerzi
jflogerzi's Avatar
Ops let me re phrase. I am doing fuel and oil first. Looking for what pump/mods to limit fuel starvation as I will be running some level of e85 and the 72.5mm pulley so about 10.5 psi and 250-260whp in ideal condistion. Also who makes the best oil baffel insert for the stock oil pan. Already have JRDC.
Old 01-12-2020, 10:59 AM   #4
Nuts & Bolts Performance
Nuts & Bolts Performance's Avatar
Drives: 17 BRZ Series.Yellow
I'd recommend the Killer B oil pick up tube and the Greddy oil pan baffle.
As for the hood vents, I think the ones from Verus Engineering are best.
Sent from my Pixel 3 using Tapatalk
Nuts & Bolts Performance is offline   Reply With Quote
The Following User Says Thank You to Nuts & Bolts Performance For This Useful Post:
kevaughan (02-27-2024)
Old 01-13-2020, 09:30 AM   #5
prandelia
Drives: 2015 FRS
Use 5W40 or 5W50. My oil pressure has been good using the v2 Moroso baffle. It's a double tier baffle, which I like, compared to some of the single tier versions. The lower tier keeps oil around the pickup.
I've had good luck using the fuel door mod for the OE gas cannister. I'm on E85 also, and my tracks allow me to run to almost E without fuel starve. Is track dependent though, and I typically still give myself some margin of safety for races.
'15 FRS - GLTC spec
YouTube channel race vids: https://www.youtube.com/channel/UClU...phsppnA/videos
prandelia is offline   Reply With Quote
Old 01-13-2020, 11:12 AM   #6
jflogerzi
jflogerzi's Avatar
Can u link to the fuel flapper mod
Old 01-13-2020, 01:01 PM   #7
prandelia
Drives: 2015 FRS
https://www.ft86speedfactory.com/vel...l#.XhyiendFyUk
'15 FRS - GLTC spec
Old 01-13-2020, 06:36 PM   #8
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
The fuel flapper helps but it won't fix fuel starve if you run on a track with long left handers. At my local track, I get fuel starve below half a tank even with the flapper valve. I'm glad I got one but I still have to fill up after 2 sessions.
14stu is offline   Reply With Quote
Old 01-13-2020, 06:39 PM   #9
prandelia
Drives: 2015 FRS
Originally Posted by 14stu View Post
The fuel flapper helps but it won't fix fuel starve if you run on a track with long left handers. At my local track, I get fuel starve below half a tank even with the flapper valve. I'm glade I got one but I still have to fill up after 2 sessions.
yeah, I'm lucky, I don't have any long-duration left hand sweepers at that tracks I go to.
'15 FRS - GLTC spec
The Following User Says Thank You to prandelia For This Useful Post:
14stu (01-13-2020)
Old 01-13-2020, 07:36 PM   #10
CSG Mike
CSG Mike's Avatar
1. DW300C
2. Bluemoon Performance baffle plate
3. you already know which vents work best!
jflogerzi (01-13-2020), Turbo (01-15-2020)
Old 01-14-2020, 02:53 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
1. DW300C
Upgrading the pump alone can solve fuel starve? Do you still need to maintain a certain fuel level?
Old 01-14-2020, 07:51 PM   #12
jflogerzi
jflogerzi's Avatar
What are you logging or looking for to detect this?
Old 01-14-2020, 08:05 PM   #13
CSG Mike
CSG Mike's Avatar
Nope, it does nothing for a slosh based starve, but dhe does need the pump for ethanol + fi where he will fuel starve from lack of flow.
finch1750 (01-14-2020)
Old 01-14-2020, 08:16 PM   #14
14stu
14stu's Avatar
Fuel starve is noticeable, at full throttle the revs drop and power is completely cut. Here's video of it happening, notice the throttle is full and rpm drop:
[ame]https://www.youtube.com/watch?v=KExSPePHn1g&t=676s[/ame]
The Following User Says Thank You to 14stu For This Useful Post:
jflogerzi (01-14-2020)
fuel setup ? KingJon1991 DIY (Do-It-Yourself) Guides 0 12-14-2018 08:22 PM
WTB: OFT, spc toe arms, baffled catch can max20s14 Want-To-Buy Requests 6 01-08-2017 03:59 AM
FS: Mishimoto Baffled Oil Catch Can zeal86 Engine, Exhaust, Bolt-Ons 7 04-29-2015 09:44 AM
Full blown fuel pump setup protpibe Engine, Exhaust, Bolt-Ons 9 04-28-2015 11:21 AM
Baffled oil pans? Stealthx Engine, Exhaust, Transmission 9 11-17-2013 08:00 AM
