Old 08-18-2019, 07:08 PM   #1
autoxtrackdrift
Drives: Take a guess...
PN for Swift Springs on KW Coilover Body
What's the correct part number and length for a pair of Swift 8k rear springs to go with a KW/Racecomp coil over?
Z60-203-080 seemed to be in the ball park if I ditch the helper spring.
Has anyone used this shock/spring combination?
autoxtrackdrift is offline   Reply With Quote
Old 08-18-2019, 11:06 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
8" is too long imho, I had an 8" 500# spring on my Bilstein and struggled to set height where I wanted in the rear, 7" 425# spring without helper was near perfect iirc and should be extremely similar to what you are looking for. 6" might need a helper spring which I think is their preferred setup.
I'd expect RCE would be able to respond to the question tomorrow if someone who has a set doesn't chime in first.
ineedyourdiddly
Old 08-19-2019, 10:15 AM   #3
Racecomp Engineering
You want 60mm ID. 6 or 7 inch length should be okay depending on where you want to set the ride height. May use helper either way with the 8 kg/mm spring rate, but definitely with a 6 inch spring.
- Andrew
wparsons (12-09-2019)
Old 12-08-2019, 03:52 PM   #4
autoxtrackdrift
Travel with 6" w/helper v. 7"
Is there any difference in travel between a 6 inch spring with a helper and a 7 inch spring alone?
Thanks!
Old 12-08-2019, 04:31 PM   #5
strat61caster
Thanks!
Any decent spring should have as much or more travel than your damper/bump stop which is tropically your limiting factor for wheel travel. A 7" spring will typically have more stroke available than a 6" spring and a zero rate helper will only change your perch height and have ideally zero impact to your wheel travel.
Check out the Eibach Motorsports catalog, they list a lot of information about block height and travel and you can compare spring stiffness and heights. You will see a general trend with small hiccups where the spring wire diameter increases but iirc is not listed.
https://eibach.com/us/rt-2-catalog-downloads.html
ineedyourdiddly
Old 12-09-2019, 10:39 AM   #6
wparsons
wparsons's Avatar
Thanks!
You can get more travel out of a longer spring before getting coil bind, but that assumes the damper has enough travel for that to be an issue with the shorter spring. On the KW/RCE bodies a 6" spring won't be binding, so you're fine either way.
flickr
Old 12-09-2019, 10:58 AM   #7
You can also look up the travel numbers for most of the major spring manufacturers.
- Andrew
Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks EGOBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-15-2018 09:21 PM
[PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs leunglambs NY / NJ / CT / PA 3 06-09-2017 03:49 PM
FS: MCS 1 way coilover with swift springs in Socal mtsui Brakes, Suspension, Chassis 8 08-15-2014 10:18 PM
Swift coilover springs 7" 8k and 7k Proof Brakes, Suspension, Chassis 2 12-02-2013 01:59 PM
swift coilover replacement springs 8k pitstops Brakes, Suspension, Chassis 0 06-14-2013 04:36 PM
