Drives: 2013 scion frs
Loud ticking post recall fix
I have a 2013 FRS automatic about 75000 miles. This is post recall fix about 1200 miles or so. I am hearing a loud ticking ever since the recall. Sounds like a card in bike spoke. It is not there all the time and it increase in speed as the car accelerates. I have been working with dealer that did recall. But currently they are saying it's the high pressure pump and that it can't be fixed. But this noise was not the before recall fix, and it does not sound like videos I have seen online of a chripping high pressure pump. They have flushed the lines and state they did find and remove some sealant. I don't know what to do next.
#2 | |
Drives: 13 Subaru BRZ
Sent from my PH-1 using Tapatalk |
| The Following User Says Thank You to ybotspawn For This Useful Post: | Outlander (07-16-2019) |
#3 |
Drives: 2013 Scion FRS 6-speed
Did they replace your serpentine belt? I had them replace the belt and spark plugs when the recall repair was done. After, I was having a noise like what you described. They said it was the fuel pump but I knew it wasn't the same sound the pump makes so I kept insisting and they offered to replace the fuel pump, after they replaced it the noise was still there, then they decided I had a bad clutch but they wanted me to pay this time, I told them the noise was there even when the clutch wasn't engaged so finally they had a "master tech" take a look to find that the new belt was defective, they replaced it and that fixed the problem.
Sent from my SM-G892A using Tapatalk |
| The Following User Says Thank You to FRS13_ For This Useful Post: | Outlander (07-16-2019) |
#4 |
Drives: car
Check that it isn't the vacuum pump issue on AT models. There was a post just yesterday about that issue.
#5 |
Drives: 13' Lightning Red Brz
I'm having the same issue, I'm going in today to get it diagnosed for the 4-5 time. So I will post an update on this.
| The Following User Says Thank You to Ichima For This Useful Post: | Outlander (07-16-2019) |
#6 |
Thanks everyone for the replies. This would be my 5th trip back as well. I will try to post a video tonight, but it's hard to capture on audio over my invidia exhaust. Yes they did replace my serpentine belt and plugs.i don't know if my garage has a master tech. Btw did you record the audio problem you had to compare. I will check the vacuum pump post.
#7 |
Here is an example of the clicking noise. Like I said it's hard to pick up but I have reduced the hum of the exhaust in an attempt to make it easier to hear. I have also included an example without the clicking so you can hear and compare.
#8 |
Ouch that does sound weird. I would get someone to rev it while sitting stationary and pop the hood see if you can pin point which side is louder and front or back of engine bay... Might help pin point problem.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | Outlander (07-16-2019) |
#9 |
Ok, I will give that a try and repost thanks, for the suggestion.
#10 |
Drives: STI
Keep me posted. Same exact issue here. I figure if it doesn't blow up I will just trade it in some day. Sucks. Literally sounds identical post recall.
| The Following User Says Thank You to subaru For This Useful Post: | Outlander (07-16-2019) |
#11 |
Senior gif poster
Drives: 2013 Asphalt FRS
just curious but did you get your TOB replaced?
| The Following User Says Thank You to DandoX For This Useful Post: | Outlander (07-16-2019) |
#12 |
That doesn't sound good at all. TBH I had those same exact noises and they ended up finding sealant in my oil pickup and oil pan. This led to a spun rod bearing. Was a hell of a fight, took them 2 months to finally be put at fault by another dealership and also a Subaru of New England Rep. I'm having a new ticking noise that's a lot higher pitched and gets louder at higher RPM's. My ticking is very quiet at low RPM's and once I pass 3k RPM's it's more visibly noticeable.
#13 |
Feeling like thinking....
Hard to tell, but it sounds a little bit like my issue.. the tech had adjusted the valves on my new engine too tight. Ask him where in the range he put them after the recall. Should be in the middle, and NOT to the tightest tolerances.
Drive like everyone's life around you depends on it...
| The Following User Says Thank You to MuseChaser For This Useful Post: | Outlander (07-16-2019) |
#14 |
Drives: Dodge Patitas
I know our engines sound like lawnmower engines sometimes, but that seems loud af. Hope it is eventually diagnosed and fixed, and don't eventually blame it on your exhaust and some excuse like decreased back-pressure was the root cause.
Sent from my Pixel 2 using Tapatalk |
| The Following User Says Thank You to sato For This Useful Post: | Outlander (07-16-2019) |
| Tags |
| noise, post recall, sealant, ticking |
| She lives once more! (post-recall damage) | BlackOptics | Northwest | 9 | 03-22-2019 07:53 AM |
| Loud ticking from engine | Norotor | Issues | Warranty | Recalls / TSB | 8 | 04-24-2018 02:45 AM |
| perrin catback resonated - loud enough or too loud? | theflathead | Engine, Exhaust, Transmission | 33 | 01-22-2018 06:46 PM |
| alright my tenth post so i can officaly post in the marketplace | destiny86 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 02-04-2016 01:49 PM |
| Engine is making a loud ticking with Redline 0w20 | KevinBRZ | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 07-29-2013 10:34 AM |
