Old 10-14-2018, 06:17 PM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
Question about track oil temperature, pressure, and viscosity
So, the Forester oil cooler option plumbed to the heater core lines is not working well for me; still hitting 270F on Laguna Seca, Sonoma Raceway, and Thunderhill Raceway with my almost stock BRZ. Oil results from Blackstone Labs says the Redline 0W-20 is doing just fine, but wear is kinda high. I don't have an oil pressure gauge, so I'm just relying on this video from savagegeese to get an idea:
From savagegeese:
0w20 Redline 225F @ 800RPM 7PSI Oil Pressure
0w20 Redline 225F @ 2000RPM 30PSI Oil Pressure
0w20 Redline 225F @ 4000RPM 48PSI Oil Pressure
0w20 Redline 225F @ 7000RPM 43PSI Oil Pressure
And I'm running 50F hotter.
Looking to professionals for how they do it, Toyota Motorsports GmbH with their 2017 86 CS-Cup they are running Ravenol 5W-50 and an oil cooler.
https://www.racingbytmg.com/en/motor...cup-downloads/
Being that I drive less than 5000 miles per year, the car is mainly for trackdays and weekend fun, and I'm prioritizing engine longevity over gas mileage, is there any reason I shouldn't go to thicker oil, a more significant oil cooler, and an oil pressure gauge? Or are there wiser options?
Picture for entertainment:
mkodama is offline   Reply With Quote
Old 10-14-2018, 06:42 PM   #2
FirstWinter
Drives: Car
High quality 0w-20 is fine. Get a better oil cooler. I like the Jackson Racing oil cooler. The Greddy one is pretty nice as well.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
treedodger (10-15-2018)
Old 10-14-2018, 07:24 PM   #3
JIM THEO
Drives: BRZ 2018
Subaru and Toyota suggest higher viscosity for heavy use while STI sells 5W40 as an upgrade oil, they know more than what we know about our engines!
I use Redline 5W30 for spirited driving and is the thickest oil in this viscosity with very high HTHS.
JIM THEO is offline   Reply With Quote
Old 10-14-2018, 08:20 PM   #4
BlueWhelan
BlueWhelan's Avatar
Drives: 2013 Blue Subaru BRZ. 6 Spd manual
If Toyota is using 40 or 50 weight oil WITH an oil cooler, then that should be a pretty good indication of what is required for a track car. If it was a daily driver I'd say 0W-20 is perfectly acceptable. However, since your car is primarily used for "track days and weekend fun," I'd say do what the pros do and invest in a track oriented oil cooler like the Jackson Racing kit, and use thicker oil. Repeated and sustained oil temps at 270 is really pushing your luck, and since Blackstone is already telling you that engine wear is higher than normal...yeah, I'd bump it up a grade or two. You're in California, so cold weather won't be a huge issue for the thinker oil.
BlueWhelan is offline   Reply With Quote
Old 10-15-2018, 02:09 AM   #5
mixxxx
mixxxx's Avatar
You need a better oil cooler.
Jackson Racing and Greddy are popular for 86Cup participants whether Stock, NA or Boosted
See data below
All OE Engine
Jackson Racing Oil Cooler
Motul 300v 0w-20
Streets CCW
Avg Ambient: 90f
Max Coolant: 203f
Max Oil: 221f
Laguna Seca
Avg Ambient: 80f
Max Coolant: 199f
Max Oil: 226f
Buttonwillow
Avg Ambient: 110f
Max Coolant: 212f
Max Oil: 232f
mixxxx is offline   Reply With Quote
The Following 3 Users Say Thank You to mixxxx For This Useful Post:
Apex No.525300887039 (10-17-2018), CSG Mike (10-15-2018), treedodger (10-15-2018)
Old 10-15-2018, 05:34 AM   #6
CSG Mike
CSG Mike's Avatar
You need a proper oil cooler.
PM me. We can discuss your needs more.
Tire Pressure and Temperature Gauges recommended for track use Toyarzee Tracking / Autocross / HPDE / Drifting 16 01-26-2016 09:23 PM
Innovate MTX-D Oil Pressure/Temperature, full set-up malave7567 Interior Parts (Incl. Lighting) 4 12-17-2015 07:10 PM
Oil Pressure and Temperature Guide Video Dezoris Engine, Exhaust, Transmission 25 05-19-2015 03:51 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 07:09 PM
Oil discussion (pressure, grades, viscosity, etc) - repost from Ferrari Chat mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 08-17-2013 01:46 PM
