Old 10-07-2018, 11:25 PM   #1
Fred Flintstone
Drives: 2015 FR-S Asphalt, racing stripes,
Subframe and Differential bushing ???
Just installed whiteline subframe insert bushings and Differential mount cradle insert bushings. Followed instructions close with no problems with bolt reinsert and proper torque spec. Now seems to have a wine through first gear after that nothing. Anyone else done the subframe and differential inserts?
Fred Flintstone is offline   Reply With Quote
Old 10-08-2018, 04:57 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Of course installing more rigid/less compliant bushings can increase NVH by not dampening vibrations/noise, that's given. Though i'd rather expect to hear some whine from gearbox mount/bushing change, not diff's, but it's after shaft next in transmission, possible. (also my guess is that whine is also in other gears, just that drowns in road/tire noise in faster speeds/lesser rpms, so you don't hear it).
Old 10-08-2018, 12:20 PM   #3
StraightOuttaCanadaEh
Wes
Yes the whine is only present in first gear
Instagram: @gt86ws
Old 10-08-2018, 01:01 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
To me whine was also in 2nd, and though rarely, sometimes i caught glimpses of that SC sound-alike quiet gear whine in 3rd too. Hence my idea that it's still there .. just that is drown among increasing other noises from tires/road/wind.
Old 10-10-2018, 10:30 PM   #5
Fred Flintstone
Thanks all just worried I did something wrong during installation. Going to be replacing differential oil anyway have about 60,000 miles on it now. Also thinking about putting some sound deading material under seats to cut some of the road noise. Anyone do the steering rack bushing. Anything I should expect from doing this? Noise, feel, vibration, anything ???
Parts Shop Max subframe and differential risers philstar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 02-20-2024 12:05 PM
Whiteline rear subframe bushing install... fl_speed001 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 07-11-2020 01:29 AM
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 12:24 PM
Outrigger bushing for Differential ??? Fred Flintstone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-06-2018 03:23 PM
FS: Whiteline positive shift (trans mount) and subframe bushing kit twincamRob Transmission and Driveline 9 02-17-2014 02:17 PM
