Old 09-22-2019, 05:09 AM   #1
gt7877
Drives: turbo frs
help on ZA1JK00D 2017
dear
plz i need help to install stage2 oft rom throw tactric openport 2.0 (ecuflash)
i need defination files and xml for ecuflash
thnx
gt7877 is offline   Reply With Quote
Old 09-22-2019, 05:11 AM   #2
gt7877
Drives: turbo frs
CLID : ZA1JK00D
Old 09-22-2019, 05:54 AM   #3
steve99
Drives: FT86
Originally Posted by gt7877 View Post
dear
thnx
K00D is not defined ie no definitions. Use K01I as a substitute rom
Or just create a flash only definiton for the K00D or K01I
Old 09-22-2019, 06:08 AM   #4
steve99
Drives: FT86
Creating a bare bones definition for flashing a ROM with no existing definition
Useful if your car has old ROM not defined and you want to try update and be able to flash back to old ROM or
you have pulled really new ROM from a car and no definition yet.
Open the rom with no definition in Ecuflash, it will tell you it does not have a definition, do you want to create one. You press yes, and then click on from scratch. Then you choose SH72531 under memory module, and Subarubrz flashing method. The unique identifier is at 8000 and 8 bytes long. Fill the rom info in with the year, model etc. - not critical that this is accurate if you're just using it to flash. Click Finish, and when you're back in Ecuflash, click on file, and 'Save Models'.
This should allow you to flash ROM but not edit as no tables defined.
Old 09-22-2019, 06:08 AM   #5
gt7877
Drives: turbo frs
thnx steve
can u send me xml K01I?
thnx
Old 09-22-2019, 06:18 AM   #6
steve99
Drives: FT86
thnx steve
thnx
see attached flash only defs
need to be unzipped and placed in
C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\subaru\BRZ\2017
folder
File Type: zip ZA1JK00D_Ecuflash.zip (432 Bytes, 156 views)
File Type: zip ZA1JK01I_Ecuflash.zip (431 Bytes, 111 views)
gt7877 (09-22-2019)
Old 09-22-2019, 06:32 AM   #7
gt7877
Drives: turbo frs
folder
dear
its open by ecuflash
but no tables
can i download it now to the car ??
https://imgur.com/viKcYfG
Old 09-22-2019, 07:09 AM   #8
steve99
Drives: FT86
I cannot see images
Those definition for ecuflash are flash only definitions. You cannpt see tune tavles, jist allows flashing of file to ecu.
gt7877 (09-22-2019)
FS: 2017 PP Sachs Dampners and 2017 stock front sway bar doctor_driver Brakes, Suspension, Chassis 2 12-26-2018 08:21 PM
CSCS Mid Summer DRIFT 2017 - Round 3 - SUN July 23 2017 @ TMP CAYUGA SB LAYOUT DTrouble CANADA 0 07-19-2017 09:42 PM
2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? Extreme Dimensions Off-Topic Lounge [WARNING: NO POLITICS] 6 06-08-2017 09:59 AM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 01:46 AM
2017 Acura NSX vs. 2017 Nissan GT-R JPxM0Dz Other Vehicles & General Automotive Discussions 1 10-19-2016 02:50 PM
