Old 07-02-2018, 01:29 AM   #1
Trickle Charger
Drives: 2018 86 AT Steel
2016 FRS rims onto a 2018 86?
Wondering if they’ll bolt right on.
Thanks for looking
TC
Trickle Charger is offline   Reply With Quote
Old 07-02-2018, 02:40 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Yes. I'd check clearance of brakes if with PP brembos though.
Trickle Charger (07-02-2018)
Old 07-02-2018, 01:39 PM   #3
Trickle Charger
Everything is stock, base model, on the 86.
Old 07-02-2018, 02:42 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Are you getting older OEM wheels as an extra set? ChurchX is correct; they will fit on your base model.
I LIKE TIRES!
Trickle Charger (07-03-2018)
Old 07-02-2018, 02:52 PM   #5
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
The brakes are the same size then, at least the rotors are for sure. pretty sure calipers too. and they both use 17" wheels 5x100 bolt pattern.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
The Following User Says Thank You to NARFALICIOUS For This Useful Post:
Old 07-02-2018, 03:01 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
Isn't even offset same?
Leonardo (07-02-2018), Trickle Charger (07-03-2018)
Old 07-02-2018, 03:17 PM   #7
NARFALICIOUS
Model Year Start: 2018 Model: 86
Tire
Size
P215/45R17, 215/45R17
Wheel
Size
17 x 7J
Material
Aluminum
Pitch Circle Diameter
mm (in.)
100 (3.9)
Inset
mm (in.)
48 (1.9)
NARFALICIOUS
Noob Poster
1988 | 2016
Old 07-03-2018, 01:19 PM   #8
Trickle Charger
That’s correct, they are a spare set with winter tires on them.
Cheers
TC
The Following User Says Thank You to Trickle Charger For This Useful Post:
Leonardo (07-03-2018)
Gauging Interest: FS OEM 2016 FRS Rims & Tires with TMPS Sensors! jordan7831 Canada Classifieds 0 05-22-2018 06:28 PM
Selling OEM 2016 17 inch rims and tires RedRez86 Wheels and Tires 14 02-11-2017 06:25 PM
FS: 2016 Stock Rims+Tires DGM-BRZ Canada Classifieds 0 08-08-2016 02:34 PM
Touge.ca 2016 Track lapping events schedule - 25+ events 2016! Touge.ca CANADA 0 03-23-2016 04:43 PM
Trade: BRZ stock rims + Michelin Pilot Super Sport for stock rims & tires + $600 Ferrari Canada Classifieds 7 05-12-2015 03:45 PM
