sleepy
Drives: Brz
Clunky 1st gear and 2nd gear
The other day I was driving around for quite awhile in 100 degree weather. I would say about two hours in traffic and freeway. I noticed the longer I drove the harder it was to engage my first gear almost like I was fighting the trans. I tried blipping the throttle a bit to get it into the gears but wasn't helping. I stopped by my dealership where I bought the car and they said it was just the short shifter that was installed from the person who owned it before me. Told me to take it out right away I'm ruining the syncros. This is what I'm really wondering... Is it my short shifter ? Because it seems unlikely my short shifter only had real problems when my car is very hot. My other theory is my trans temps are too hot and that's why I can't engage into first and second. Let me know what you guys think. Thank you all.
Sent from my Pixel XL using Tapatalk |
#2 |
Drives: FRS 2013
I would try a trans fluid change, usually shifting gets easier as the fluid warms up
#3 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Are you properly rev-matching? 1st is notoriously difficult to get into while moving if you DO NOT properly rev match. People tend to underestimate how many RPMs 1st gear requires when downshifting. It's a short gear.
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#4 |
sleepy
Drives: Brz
#5 | |
sleepy
Drives: Brz
#6 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
yea definitely wouldn't be due to "high" temps, shifting on this box feels the best after it's warmed up...
what about going into 2nd first and then into 1st? |
#7 | |
That might be worth checking out. What do you think, there @Ultramaroon ..?? humfrz |
#8 | |
sleepy
Drives: Brz
#9 | |
sleepy
Drives: Brz
| The Following User Says Thank You to Sleepyyysam For This Useful Post: | humfrz (05-22-2018) |
#10 | |
If there is ANY play allowing the shift lever to rotate about the vertical axis, the adapter is loose. If that's the case, I recommend removing and tossing it into the nearest dumpster. I have a deep hatred for that piece of shit.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Sleepyyysam (05-23-2018) |
#11 | |
![]() Well, that's one way of "fixing" it .. ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (05-22-2018) |
#12 |
sleepy
Drives: Brz
Well boys, I ripped everything apart to try and see if something was broken and didn't really see much. I have to drive it to and from work so threw it all back together. Now the car is shifting perfect. As if nothing ever happened... I'm going to drive it harder than usual tomorrow and see if it's still working well. Maybe something wasn't aligned correctly? Either way thank you guys for the replies !
| The Following 2 Users Say Thank You to Sleepyyysam For This Useful Post: | humfrz (05-23-2018), Ultramaroon (05-23-2018) |
#13 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sleepyyysam (05-23-2018) |
#14 | |
There's a procedure in the manual which involves feeler gauges but it's kind of overkill. The middle of the gates are easy enough to feel by hand.
| Anyone feel like they have a clunky gear change? | Haseebali31 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 04-16-2022 03:52 PM |
| Clunky and hard gear shifts | nhuyvan1106 | Issues | Warranty | Recalls / TSB | 45 | 08-26-2017 02:52 PM |
| Gear indicator (G-on) shows 2 when in 3rd gear | c8Face | BRZ First-Gen (2012+) General Topics | 31 | 07-07-2017 08:23 PM |
| Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl | jakebrz | Issues | Warranty | Recalls / TSB | 14 | 06-06-2016 07:28 PM |
| No more 1st gear thump or 2nd gear notchiness | kc4mne | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 09-06-2012 09:39 PM |
