Old 03-19-2019, 12:56 PM   #1
Pescator
Drives: 2015 FRS
Brakes, Tires, Spacers?
Looking to do my first round of upgrades on my 2015 FR-S. I try to make it to the track a few times a year and am looking to see some improvements. Note this is my everyday car so don't want anything too problematic for street. What do folks recommend?
-Brakes- Powerstop? Carbotech?
-Tires- Hankook RS4s? How wide can I get for stock wheels? Staggered?
-Spacers- Needed to maximize wider tires?
Pescator is offline   Reply With Quote
Old 03-19-2019, 03:24 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Brakes
http://www.ft86club.com/forums/showthread.php?t=25485
http://www.ft86club.com/forums/showthread.php?t=23680
Depends on where you're at and if you want to swap back and forth between events and DD, Carbotech/Gloc offer compounds that are livable on the street, XP10/R10 was my starting pad but I wasn't able to keep them bedded in and swapped back to street pads after the track days. Ferodo DS2500 gets love as a hybrid pad but will eventually fall short as you go faster, perfectly tolerable on the street in my experience but I won't ever put them on track they're my autox pads.
RS4 is a solid choice in OE size, maybe 225/40/17 can work but you'll lose feel, for the 17x7 I'd say stick with OE size, don't stagger
OE size or 225 are no issue, plenty of clearance with a 17x7 or 7.5 to everything. 17x8 with lots of camber gets close and you'll need spacers if you're going for more than -3°
Get camber bolts, max out your camber up front, -2° won't be bothersome on the street and will help tire wear and grip up front, big improvement for $20-$30 plus alignment
http://www.ft86club.com/forums/showthread.php?t=103609
ineedyourdiddly
treedodger (03-20-2019)
Old 03-19-2019, 04:32 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Brakes - Winmax W3 if doing double duty track/street
RS4 are a decent choice. If you are looking to improve your skills GT Radial SX2 would be a better one though. Last longer, communicate, not as much grip as a 200TW but still sufficient. Will help you improve as a driver faster then a RS4 or similar
No spacers. Camber bolts and max the front camber though. Do you have any other suspension mods?
Old 03-19-2019, 04:38 PM   #4
fminicooper
Drives: FRS Hot Lava
I will try to be short an easy, plenty of information about your topics in the forum.
As strat61caster point out, those threats are mandatory to read if you go to track.
http://www.ft86club.com/forums/showp...&postcount=374
At least: Brake Fluid / Front Pads.
Running Falken Azenis RT615+ 225/40/17. Happy with them. Decent result on wet.
Not Staggered.
Personally I will not use any spacer in Track Conditions.
fminicooper is offline   Reply With Quote
Old 03-19-2019, 05:06 PM   #5
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Spacers - never!!
Rather make another plan like more camber.
Fish Eagle is offline   Reply With Quote
Old 03-19-2019, 05:14 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Originally Posted by Fish Eagle View Post
Spacers - never!!
I understand where you are coming from, but spacers cost so much less than another set of wheels or coilovers. So for many of us on a budget, they work great on the street and track.
I LIKE TIRES!
Old 03-19-2019, 05:26 PM   #7
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Hey, if you prepared to run with the cheapest budget tyres, then go for spacers.
If not, then don't...
If you on a budget, and all you can afford are spacers, then rather buy a case of beer
More fun, and beer won't kill you
Old 03-19-2019, 07:32 PM   #8
AFRichZC6
AFRichZC6's Avatar
How much experience do you have with track days? Lots of things depend on that.
Compound selection depends many factors - your tires, track conditions, driving style, experience, preference. If you're a novice with so-so 200TW tires (not Bridgestone RE71R or BFG Rival S), you may be alright with "hybrid" pads that have a wide operating temperature that covers daily driving up to light track duty, like Ferodo DS2500 or Hawk Street/Race.
Square setup. Stock tire size is probably best fit for the stock wheel, or you can try 225/45R17.
But y tho
AFRichZC6 is offline   Reply With Quote
Old 03-20-2019, 12:40 PM   #9
Pescator
Drives: 2015 FRS
I have 6 track days under my belt. Looking to run 2-3 times a year.
But y tho
Old 03-20-2019, 12:49 PM   #10
Leonardo
Country Boy 4 Life
Leonardo's Avatar
So, if I'm on a budget I should buy beer instead of save for better parts? That makes no sense. Also, FYI, Beer can kill you; It has killed a few of my friends. Where as, I don't know anyone that has been killed by "Spacers".
I LIKE TIRES!
Old 03-20-2019, 01:45 PM   #11
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
I've been through a couple sets of PowerStop Trackday pads. They are great if you are just starting off an want an inexpensive pad you can use on both the street and track. They are well matched to street tire (like SX2 (TW260)):
POWER STOP PSA1124
POWER STOP PSA1539
(The PSA is better than the PST compound; higher friction and temperature capabilities. Available at rockauto.com)
For more info, read my review:
http://www.ft86club.com/forums/showp...&postcount=369
If your stock tires still have at least 4/32in of thread, use those.
I would also advocate for a higher treadwear tire if you are starting off, as they provide more feedback and and slip angle (which is great for learning).
https://yousuckatracing.wordpress.co...aining-wheels/
I would also recommend fresh brake fluid, ATE Type 200 or Motul RBF600.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
Old 03-20-2019, 02:31 PM   #12
redlined600
redlined600's Avatar
Drives: Fr-s
Work great for what?
As others have already said, you'd be much better off using the money from spacers for camber bolts and an alignment.
redlined600 is offline   Reply With Quote
Old 03-20-2019, 02:38 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Well, on my car they add room between the tire/wheel and spring perch for more camber. Additionally, Lots of guys use them so their wheels fit after adding a BBK.
I LIKE TIRES!
Old 03-20-2019, 05:12 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
spacers are fine as long as they are used with extended studs and are hubcentric to prevent slippage. pair that with open ended lug nuts and I don't see what the issue would be, other than having to change out the studs.
if you're using bolt-on spacers, then you need to rethink your cost/benefit analysis.
rice_classic (03-21-2019)
brakes, spacers, tires
new wheels tires and spacers help please please please uwrasta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-04-2017 12:41 PM
FS: OEM Subaru Legacy GT wheels with tires and spacers booyaka Wheels and Tires 13 02-06-2014 03:30 PM
Spacers with RCE Yellows on Stock Rims/Tires? husker741 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 05-04-2013 05:21 AM
New Vendor - Intro- M R Tire Solutions of Southern California - Tires-Wheel-Brakes MIKE@MRTIRESOLUTIONS Wheels and Tires 2 12-13-2012 07:59 PM
Wheels tires suspension chassis brakes Calum Site Announcements / Questions / Issues 1 07-15-2012 12:14 PM
