Old 04-05-2018, 06:56 PM   #1
cat94
Drives: '17 86
Clutch Spring C-Clip Size
Hi Everyone,
I finished installing my MTEC Clutch Spring, but I dropped the c-clip. All I heard was a quiet clang and it was gone forever. So a couple questions:
(1) Can the missing c-clip possibly cause any issues down the line? (e.g., shorting wires, etc.) Should I try to find it?
(2) What size is the c-clip?
(3) How the heck do I get it on when I find a replacement? My fingers didn't work, and I tried clamping it on using pliers which caused it to fly somewhere.
Image for reference:
Thanks!
cat94 is offline   Reply With Quote
Old 04-05-2018, 07:27 PM   #2
e1_griego
e1_griego's Avatar
Drives: Many
My local napa has a kit full of little C-clips like that. I'd take the pin to local parts store and find one that works.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
humfrz (04-05-2018)
Old 04-05-2018, 07:34 PM   #3
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I had the same problem but worse. When I knocked out the clevis pin it flew behind the metal panel on the left against the fire wall.
Perhaps it fell behind their somehow?? I used a magnet pen and was able to fish it out.
Old 04-05-2018, 07:38 PM   #4
cat94
Drives: '17 86
I tried running a magnet around but don't remotely know where it fell. =(
I even taped up the crevice between the carpet to prevent this.
Old 04-05-2018, 08:20 PM   #5
Originally Posted by cat94 View Post
Hi Everyone,
I finished installing my MTEC Clutch Spring, but I dropped the c-clip. All I heard was a quiet clang and it was gone forever. Thanks!
It's twice further away that you think it should be .........
Handy tool ...... which you will only use twice in your lifetime ..... but it will be worth it.
Old 04-05-2018, 10:57 PM   #6
cat94
Drives: '17 86
Yep, it's definitely a goner. I'll give that tool a shot!
Anybody happen to know the diameter/size of the pin/c-clip? Would save me the trouble of removing everything
Old 04-05-2018, 11:45 PM   #7
I don't know the size of the clip ...... but, if you don't want to take the pin out and into the store with you ....... I'd suggest you just go to the store and buy about a half dozen sizes that look like they would fit. Get two of your best guess size, in case the first one escapes .....
Old 04-06-2018, 03:43 PM   #8
daskaman
Drives: Burz
4 or 5mm if I remember. Popping mine off with needlenose I swear it just vanished.
I bought a kit of e clips off amazon and it was one in the kit
daskaman is offline   Reply With Quote
Old 04-06-2018, 07:06 PM   #9
cat94
Drives: '17 86
Just did the same. Not sure what I'm going to do with 200 of these things though.
I got lucky when I popped it off... it flew off but the grease made it stick to my hand when it landed.
The Following User Says Thank You to cat94 For This Useful Post:
daskaman (04-10-2018)
Old 04-07-2018, 04:08 AM   #10
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Hi Everyone,
Thanks!
I lost mine before too. Luckily, one of my friends is a Toyota tech and was able to pull the part number:
"Clip: SU003-00058"
EndlessAzure is offline   Reply With Quote
The Following User Says Thank You to EndlessAzure For This Useful Post:
gravitylover (04-08-2018)
Old 04-07-2018, 06:45 PM   #11
cat94
Drives: '17 86
"Clip: SU003-00058"
Thank you!!
Old 04-10-2018, 02:47 PM   #12
DrButtDrugs
yerp
Drives: 2015 WRX
Anyone know if the c-clip can be caught with a magnet?
DrButtDrugs is offline   Reply With Quote
clutch spring question mr.brz1234 Engine, Exhaust, Transmission 10 09-07-2017 09:59 AM
FS: MTEC clutch spring nunonuna Transmission and Driveline 2 07-13-2016 12:34 PM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Clutch spring removal Sandy AUSTRALIA 4 07-22-2015 10:14 PM
