Drives: Panda FR-S
Car sputtering and cutting power at WOT
As I approach 150k miles and 130k boosted miles on my car, I'm starting to see issues. I'm not sure if I have a vac leak but when I WOT my car, power is cut and the engine doesn't want to climb in rpms at random times. It just hangs at say, 4k or 5k rpm under WOT. It happens quite a bit. It's more pronounced on pump gas than e85. I'm thinking this could be the effect of a vacuum leak somewhere. I'm not sure what else can cause this.
Any one else experience such issues?
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
#2 |
Huge E85 fan!
Drives: 2016 Scion FRS
Vacuum leaks usually happen at low RPM, not high RPM. That is not a typical vacuum leak symptom
#3 |
Wes
Failing fuel pump? Coil pack? Spark plug? Clogged injectors?
#4 |
Drives: 2014 BRZ
Perhaps failing MAP sensor? A lot of these OMNIs are shitting out on people lately.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
| The Following User Says Thank You to Amputechture For This Useful Post: | Fred E (10-18-2017) |
#5 |
I Love custom Turbo kits
Drives: Limited BRZ
What does your AFR look like when it happens, have you taken a log to see timing, engine load, boost when the issue happens? Is it particular to a single gear? etc..
#7 |
Drives: WRB BRZ
+1 for the MAP sensor as well. There have been several reports of Omni MAP sensors failing, and the symptoms fit.
#8 |
Huge E85 fan!
Let's see LTFT and STFT at idle, 2500 RPM and WOT
#9 |
Drives: Panda FR-S
Thanks! I'll try to gather this info this weekend.
#10 |
Drives: Q5 + BRZ + M796
Clogged fuel filter?
#11 |
Drives: Panda FR-S
I've attached some data logs. I don't know if they indicate anything. Basically I give the car some throttle and right before i let off the throttle is when the engine dragging starts happening. Basically the engine sounds like it's struggling and doesn't rev higher even with throttle. Not sure if it's a misfire or what. What's interesting, it's worse the lower the ethanol level. Basically the car performs better with higher E content and performs like crap on pump gas. This issue just started happening.
If anyone sees anything wrong, Thanks
#12 |
Your AFR and MAP is pretty wild, along with some fuel trims.
Replace your MAP, or test with a known MAP. |
#13 |
Drives: 2016 Scion FR-S
Interesting I'm experiencing the problem once and awhile these past about 3 months now. I have about 35k miles with less than 10k on boost (JRSC C38) on stock MAP. It's happened on 91 and e85. I can't figure it out.
This is a data log using Torque App over a month ago. https://datazap.me/u/dru670/engine-s...17-18-19-20-21 Been meaning to do a data log with ecutek to have my tuner take a look at it. |
#14 | |
Drives: 2014 BRZ
| Help, engine sputtering problems | carproblems | Engine, Exhaust, Transmission | 17 | 09-07-2015 12:38 AM |
| Engine cutting power after hard cornering... | CSG Mike | Tracking / Autocross / HPDE / Drifting | 19 | 07-04-2015 09:40 AM |
| Sputtering sound from right speaker when going over bumps fast? | l0aded | Electronics | Audio | NAV | Infotainment | 2 | 06-03-2013 03:47 AM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
| Engine cutting power after hard cornering... Video inside | CSG Mike | Engine, Exhaust, Transmission | 4 | 08-21-2012 09:06 AM |
