Old 03-10-2016, 07:54 AM   #1
dp1
driving smoother faster
Drives: Sold
Oil pressure/temp gauges & block8head.com gauge pod
Looking at getting dedicated oil pressure and temp gauges and already have p3. Would like to free up obd2 (disconnect p3) so I can log with my MX wifi odb2 while on track.
Not sure if the block8head.com pod (ideal placement for me) is sturdy enough for track, especially the dual pod. Alternatively I could put a single oil pressure gauge on top and oil temp in vent instead of p3.
Your experience with the dual block8head gauge pod on track/ax? Thx
dp1 is offline   Reply With Quote
Old 03-10-2016, 09:25 AM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
I hear they are good and wish he was making those when I did my gauge. I just have a factory pillar that I had a guy mould a pod it turned out really well and looks OEM
dp1 (03-10-2016)
Old 03-10-2016, 11:01 PM   #3
dp1
Drives: Sold
Also, did anyone install new sensors for both oil pressure and oil temperature? I saw posts on the oil pressure sensor but still searching for the best oil temp sensor location. I know I can read oil temp via odb2 but would like to free it up.
Old 03-12-2016, 05:20 PM   #4
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
im using their single vent pod since im using the ATI vent pod its nicely built using OEM vent
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
The Following User Says Thank You to BRZtoni For This Useful Post:
dp1 (03-12-2016)
Old 03-13-2016, 11:02 AM   #5
xwd
There are some threads on this but there is another tap location on top of the block. I use that one for oil pressure and then just replaced the factory oil pressure warning sensor with the temp one.
The Following User Says Thank You to xwd For This Useful Post:
dp1 (03-13-2016)
Old 03-13-2016, 11:53 AM   #6
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
they do sell dual monitor gauges which im using
Flex Fuel Turbo BRZ
dp1 (03-13-2016)
Old 03-13-2016, 07:31 PM   #7
dp1
Drives: Sold
Thanks, did you have a chance to compare oil temp readings from the new oil temp sensor you installed in the oil pressure warning sensor location to the oil temps from stock sensor, accessible thru odb2?
Old 03-14-2016, 05:00 PM   #8
dp1
Drives: Sold
I've been introduced to Stack gauges and like their flash-beyond-threshold design. Gauge model: http://www.summitracing.com/parts/sgg-st3502/overview/
Could 120-130psi cold start pressures damage this 100psi max gauge in any way? I assume not but please chime in.
Old 03-14-2016, 06:57 PM   #9
Blue Gt
Blue Gt's Avatar
Question Aftermarket gauges for the twins
I asked about these on the STX thread but have no response yet. I am wondering if anyone has tried the Longacre stepper motor gauges in a twin?
Blue Gt is offline   Reply With Quote
Old 03-15-2016, 04:15 PM   #10
dp1
Drives: Sold
Ok, ordered Stack 3502 gauge and single vent gauge pod from block8head.com. Will be installed by EFI Logics by mid-April. Was considering both oil pressure/temp gauges but pressure is key and I can glance at the p3 gauge only when I see that the pressure gauge is flashing...less things to be distracted by in the direct field of vision. Thanks for responses
Old 03-18-2016, 02:47 PM   #11
FRSKEV
Drives: FRS
Post them up when you get them installed
2013 Scion FR-S
Autox - Track
Paint Protection Film Pro
FRSKEV is offline   Reply With Quote
The Following User Says Thank You to FRSKEV For This Useful Post:
dp1 (03-18-2016)
Old 04-22-2016, 07:26 PM   #12
dp1
Drives: Sold
Need to configure the pressure gauge but it's bright, it looks great and it changes colors (white/green/? - haven't read instructions or pushed it into the danger/blinking mode yet, that one is probably red)
Top left is Stack pressure 0-100 PSI gauge, bottom left is P3 (I keep it on oil temp) and the right gauge is AFR/boost. I'll take better pictures when I have some time.
Old 04-23-2016, 05:33 PM   #13
dp1
Drives: Sold
Better pictures
The Following 2 Users Say Thank You to dp1 For This Useful Post:
DocWalt (04-23-2016), gkubed (02-03-2019)
Old 04-24-2016, 12:17 PM   #14
Alan
Alan's Avatar
Drives: 2013 SWP BRZ Ltd. / E60 M5
Danko - how solid is the mounting of the blockhead part? Thinking about the 2 or 3 pod model. Going to run DEFI gauges.
2013 BRZ Limited | SWP | Verus Ventus 1 and High-Efficiency Rear Wing | Invidia N1 Ti | JR Oil Cooler | RCE T2 | RaceSeng Cas/Cam | SPL LCA & TA | Wilwood/RR Racing Stage II/Sport Performance | XP10 | Apex ARC-8 | Toyo R888R | 245/40-17 | Sparco Ergo II/Evo II | AIM MXP | SmartyCam GP HD 2.2
Alan is offline   Reply With Quote
The Following User Says Thank You to Alan For This Useful Post:
dp1 (04-24-2016)
Block8head defroster vent gauge pods (all 52mm varieties) with pictures. Cheeseballs Cosmetic Modification (Interior/Exterior/Lighting) 25 03-20-2016 11:46 AM
Fs: block8head single gauge pod and AC vent pod with reducer ring protpibe Interior Parts (Incl. Lighting) 4 02-13-2016 10:03 PM
WTB: Block8head Vent Pod (60mm) Xiao Li Want-To-Buy Requests 0 09-25-2015 02:07 PM
WTB: P3 Vent Gauge Akari Want-To-Buy Requests 0 08-15-2015 10:59 PM
Defrost vent single gauge pod spitfire481 Interior Parts (Incl. Lighting) 5 07-03-2014 09:58 PM
