Old 11-18-2012, 01:10 AM   #1
Ingen
Drives: Ultramarine FR-S 6MT
Metallic buzz over 4000 rpm?
Hey guys.
I was having some fun on the back roads today and noticed a new sound. There's kind of a metallic raspy buzz now, along with the engine sound of course. I have the car stock and wondered if it could be a bolt on that system, or,of it was maybe something else. Almost sounds like a bolt rattling loose, from approximately somewhere forward of the dash. Haven't focused on it enough to really pinpoint, and I am thinking of jacking it up for a look see in the morning.
Anyone have a high rpm specific noise other than engine yell?
Thanks in advance.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 11-18-2012, 05:43 AM   #2
Kev01
Kev01's Avatar
Drives: Toyota 86
Had a similar sound while cruising on the freeway under acceleration. However, the noise disappeared the next day... Been a week and all looks fine. I suspected something to do with the exhaust sound amplifier. Let me know what you find.
Kev01 is offline   Reply With Quote
Old 11-18-2012, 08:38 AM   #3
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Funny i get the same noise when i pass 2000 and it get louder the higher rpms you go but it sometimes doesn't happen. It's pretty faint when driving normal but its still there. I was going to take it in but considering how it only happens every now and then it might have to do with gas. I'm still checking into it and it happened around 1200 miles. You are not alone sir. I thought it was the chime noise that everyone else got but it only happens when you press down on the pedal.
rhood168 is offline   Reply With Quote
Old 11-18-2012, 09:05 AM   #4
nix
nix's Avatar
Drives: AVO BRZ
I get this occasionally, when up shifting at high revs and wot, like a burst of a rasp for a moment before the revs drop. Exhaust shield type sound.
nix is offline   Reply With Quote
Old 11-18-2012, 09:55 AM   #5
Frostyman
Drives: 2013 Raven FRS
Same behavior here, and I run only 93 octane, so I doubt it's got anything to do with the fuel quality. Can cross that off the possibilities list I guess.
Frostyman is offline   Reply With Quote
Old 11-18-2012, 11:01 AM   #6
Shagaliscious
Drives: Firestorm FR-S (MT)
Is this the sound?
[ame="http://www.youtube.com/watch?v=-zsPn6YMf5g"]2013 FRS buzz when clutch partially engaged/slipping - YouTube[/ame]
Although he doesn't seem to know what it is either.
Old 11-18-2012, 11:20 AM   #7
whtchocla7e
Drives: 2013 FR-S Hot Lava
I definitely do not have the same sound as in the video. Knock on wood!!!
Live to drive another day
whtchocla7e is offline   Reply With Quote
The Following User Says Thank You to whtchocla7e For This Useful Post:
winsometang (02-06-2013)
Old 11-18-2012, 01:51 PM   #8
rhood168
rhood168's Avatar
No that is real bad and I would of taken it in asap. The noise I get is not that loud its more of a light buzz . That vid sounded like he was drilling a hole in the dashboard and engine. I hope no one gets that sound cause damn...lol
Old 11-18-2012, 03:53 PM   #9
Yruyur
Yruyur's Avatar
Sure it's not this issue.
http://www.ft86club.com/forums/showthread.php?t=17964
I fixed mine by installing the washers. When I had Toyota replace my transmissions the noise came back. I think they didn't install the washers again.
Sent from my flux capacitor using Taptalk
Old 11-18-2012, 03:53 PM   #10
Yruyur
Yruyur's Avatar
You can lay on the ground and see if that shield moves by hand. On the passenger side.
Old 11-18-2012, 05:04 PM   #11
Ingen
Originally Posted by Shagaliscious View Post
Is this the sound?
Nope, that one would drive me INSANE so I'm glad that's not it. The one I have now is kind of driving me batty, anyway
I may go digging for it this evening.I don't think it's the skid plate (though I may preemptively fix that one) and I went down the freeway at about 5krpm today looking for it. I could not get my hands on anything on the dash that muted it, but the shifter seemed to have a rattle of its own that changed when I grabbed it. Go figure huh?
Blahhhh.
Oh well. Part of the thrill yeah?
PS, these are a hoot:
I was blown away by the sport button - what a rush, and SO EASY to keep up with. NO correction needed. Poetry in motion, honestly. <3
But that damn rattle...
Old 11-23-2012, 01:40 PM   #12
Yruyur
Yruyur's Avatar
Any update on this. My washers are on there but still having this buzz.
Old 11-23-2012, 07:53 PM   #13
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Put your hand on the rear view mirror and see if the buzz goes away.
Mine rattles against the windshield. I swear it sounds like it's something loose inside the dash, but holding the mirror instantly makes it go away. I've stuffed a piece of folded paper between the top of the base and the windshield and that helps.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 11-27-2012, 01:25 AM   #14
lavisxice
lavisxice's Avatar
Drives: WRB BRZ
if its like a high pitched noise im having some too
2013 WRB Subaru BRZ Sport-Tech
-TRD intake
-Perrin 2.5 inch cat-back exhaust
lavisxice is offline   Reply With Quote
Installed Amp & Speakers, getting constant buzz Gir Electronics | Audio | NAV | Infotainment 8 11-16-2012 02:28 AM
Continuous BUZZ/HUM from HPFP in ACC mode. stevo_12v AUSTRALIA 2 10-22-2012 05:46 AM
Metallic based tint DSOmegaX BRZ First-Gen (2012+) — General Topics 11 08-26-2012 02:15 PM
DBA 4000 T3 Slotted Rotors for BRZ/FR-S at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-07-2012 12:41 AM
Canadian Pricing Prediction: Scion cheaper by $4000 minimum. pastuch Scion FR-S / Toyota 86 GT86 General Forum 6 11-03-2011 08:44 PM
