| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2016 Scion FRS Halo
What is the point of changing coolant if it get's constantly replaced?
Based on the maintenance schedule of the coolant:
1st replacement interval is 11 years/137,500 miles (220,000 km). 2nd replacement interval is 6 years/ 75,000 miles (120,000 km) after the 1st. ...I don't really understand the point of replacing the coolant. Why would it need to get replaced if you're constantly replenishing it? Especially during a long period of 11 straight years, wouldn't it have been replaced several times over? Edit 1: When did I ever say it was being replaced constantly? I said "constantly replenishing". Constant could be any frequency. The definition of constant means occurring continuously over a period of time. So let me be specific, "topping off when needed". Also my car is still relatively brand new, under 10k miles. There aren't any signs of leaks that I know of, so it's doubtful I have a leak. Last edited by ghostzfh; 10-23-2017 at 06:00 PM. |
#2 |
I think therefore.....
Drives: Toyota 86 860 Halo White (Manual)
What? How is it being replaced constantly? Unless you have a serious leak it would never happen.
Me thinks there is a piece of the puzzle missing.
May the N.A. force be with you.
| The Following 2 Users Say Thank You to Darth Khan For This Useful Post: | 22R (10-23-2017), new2subaru (10-23-2017) |
#3 | |
Drives: 2005 Toyota Camry
It's like saying "my car burns a quart of oil every month, every 6 months I have an oil change so I don't need to change my oil" |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
Wow kids theses days. Would not be surprised if he clams he's an engineer of some kind.
Any who, short answer, the coolant brakes down over time and it's not as effective. Your Google-fu is weak young grasshopper
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | N8RH8R (10-26-2017) |
#5 |
I'm new to the FRS, just got mine a month ago, but reading around here I've seen several people talk about these cars eating coolant. I can't say if mine does as I just got it. But I think the OP was sort of referring to that issue. If you're eating through and topping off the coolant at a higher rate than the scheduled interval then theoretically you've changed it a few times. Just speculating on what the OP was getting at. I'm not sure how widespread the coolant eating problem is or at what rate they are eating it.
#6 | |
I think the OP was kind of poking fun out of frustration that his car is using coolant. |
#7 | |
I'm willing to be corrected on this one but if my twin was eating coolant to that extend I would be checking for leaks and doing a coolant system pressure check. (Or getting the dealer to check it under the warranty).
#8 |
See Edit #1.
#9 |
#10 |
BRZZZZZ
Drives: 2013 BRZ Whiteout
I have owned the car for 3 yrs now and I have only topped the coolant once myself (roughly .2liter) and once guys at Subaru dealership did during the oil change. BRZ has 7.2L of coolant (for manual car). I hardly doubt you will be "replenishing constantly" to add 7.2L of coolant in 11years. If you do have to add that much coolant, then you have bigger problems.
| The Following User Says Thank You to Sideways For This Useful Post: | mav1178 (10-23-2017) |
#11 | |
The point of replacing coolant is so that you replace the capability of it to 1) protect the cooling surfaces it contacts, and 2) continue to act as antifreeze. Additionally, since there is no filtration capability, replacing the coolant in its entirety means you can remove any contaminants that are suspended in it. "Topping off when needed" is great if it was pure water and nothing else, except if you ran only water the insides of your engine block would soon lose the ability to transfer heat to the water. Aluminum blocks oxidize over time as well as iron blocks, and once this takes place you will find it increasingly difficult to run the engine cool, especially if you take it to the track or otherwise live in very hot/humid conditions. The entire point of having to replace coolant is so it continually provides the ability to cool your engine over time. The reason why the interval becomes more frequent over time is because the manual is written assuming some corrosion with the stock block will happen, thus you need to increase the frequency you replace the fluids as mileage or time increases. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | Beachin86 (10-23-2017) |
#12 |
For sure don’t run pure water. Your water pump will be gone in no time at all. I live in Florida so the antifreeze aspect is rarely a concern. It’s the anticorrosion properties that are critical here.
| The Following User Says Thank You to ermax For This Useful Post: | mav1178 (10-23-2017) |
#13 |
Yup, it's why the manual is written the way it is, for people that don't understand how cars work.
#14 |
Persona Non Grata
Drives: '15 BRZ (WRB)
Admit it, it is something we've wondered at one time or another, right? In my teens I had a friend who owned a Rambler. It burned about a quart of oil every 500 to 1000 miles. He decided there was no point in changing it since it was effectively changing itself every 5000 miles. In fact, we thought the car was better off because it always had 2 quarts in it that were less than 2000 miles old.
It ran like that for several years until some f&^kwit stole the thing and ruined our experiment. If memory serves, one of the Car Talk guys, Tommy, I think, did the same thing to a Dodge Dart. I don't recall how the car died, but it ran for a long time. The key is that the consumption/replenish rate be high enough that the chemistry of the fluid is constantly being renewed.
Slow is smooth, and smooth is fast
| Tags |
| coolant |
| Checking and Changing BRZ/FR-S Engine Coolant | GrimmSpeed | DIY (Do-It-Yourself) Guides | 39 | 05-29-2023 09:15 AM |
| Consensus on changing whole transmission versus changing solenoids | dem00n | Engine, Exhaust, Transmission | 7 | 07-20-2016 04:50 AM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Automatic headlights constantly on? | Drakelee117 | BRZ First-Gen (2012+) — General Topics | 21 | 08-31-2015 06:26 PM |
| Posts deleted constantly | gmookher | Site Announcements / Questions / Issues | 6 | 12-10-2012 06:06 PM |
