Old 06-05-2017, 10:09 PM   #1
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Leaky weld on Tomei UEL header
I have been popping P0171 codes randomly over the last month or so. Seems to happen mostly when I am sitting at idle.
Last week I bought and installed a slightly used Berk HFC front pipe so while I was under there, I decided to check everything out for leaks. Yup...just about every gasket/fitting was leaking to some degree or another. The slip joints on the Tomei were the worst, but I also thought I saw the weld on the passenger side header flange/pipe joint leaking but it was hard to tell with it installed.
I ordered all new gaskets and pulled the front pipe, over pipe and header off the car and rigged up a pressure test jig and pumped some low pressure air in. I'll be damned if there wasn't a pinhole leak in the weld!
Found a local guy last week that does awesome work welding stainless (fixed some cracks in the Berk FP for me last week) so I'll be paying him another visit tomorrow. Exhaust really blows (literally and figuratively)...almost as bad as plumbing!
[ame="https://www.youtube.com/watch?v=ycZxavgty34"]Tomei UEL header weld leaking - YouTube[/ame]
BirdTRD is offline   Reply With Quote
Old 06-05-2017, 10:30 PM   #2
AceHeader-MT
AceHeader-MT's Avatar
Drives: 2012 FR-S
Nice test stand. You should consider selling to Tomei and others
AceHeader-MT is offline   Reply With Quote
The Following 3 Users Say Thank You to AceHeader-MT For This Useful Post:
BirdTRD (06-05-2017), new2subaru (06-06-2017), Teseo (06-05-2017)
Old 06-05-2017, 10:42 PM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
How about a trade? My test jig for a shiny new Ace Header! I heard they pair nicely with the Edelbrock SC kit.
Old 06-05-2017, 11:14 PM   #4
CSG Mike
CSG Mike's Avatar
CSG has a nice Ace header that should be back from Ceramic coating soon for you
Old 06-05-2017, 11:49 PM   #5
Teseo
Drives: frs
Never seen a fail on tomei, glad i went jdl
Old 06-06-2017, 10:35 PM   #6
BirdTRD
Simply Forgotus
BirdTRD's Avatar
So it turns out to be a 1/2" long hairline crack across the weld at that flange/pipe joint. Welder should have it fixed tomorrow.
Now I need to figure out what to do about those leaky slip joints..besides buy a new header ( @CSG Mike @AceHeader-MT)..mines only 2.5 years old!
I'm open to suggestions!
Old 06-06-2017, 10:58 PM   #7
AceHeader-MT
Drives: 2012 FR-S
A simple fix to maybe solve slip joint leaks (cheap and easy):
- Use a pipe expander, crank out the inner tube and apply furnace cement. Then insert back into joint.
Furnace cement will harden and look ugly but if you ever want to remove (or sell) just wire brush and it'll come right off, no damage to tubing.
Outside of that, I can't think of any simple solutions. Welding them would be a bad idea.
Good luck and hope it works out. Any questions let us know
The Following User Says Thank You to AceHeader-MT For This Useful Post:
BirdTRD (06-06-2017)
Old 06-06-2017, 10:59 PM   #8
CSG Mike
CSG Mike's Avatar
Repair the weld. That's a quick job; should be very inexpensive.
Old 06-06-2017, 11:22 PM   #9
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yeah, gave it to the Welder today so it should be ready tomorrow. Shouldn't be more than $20.
Old 06-06-2017, 11:39 PM   #10
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Not sure what you mean with the pipe expander...aren't those inserted into a pipe opening to stretch it to a larger diameter?
Once I remove the "brackets" that span from one side of the slip joint to the other, should the pipes just slide apart or is there tool I need to get them apart?
I was thinking that once I get them separated, smearing some High Temp Copper RTV in there as it should stay semi flexible...if it can stand up to the temps there.
Old 06-07-2017, 01:30 PM   #11
BirdTRD
Simply Forgotus
BirdTRD's Avatar
$10...can't beat that.
The Following User Says Thank You to BirdTRD For This Useful Post:
CSG Mike (06-07-2017)
Old 06-20-2017, 10:25 AM   #12
Varelco
Drives: '15 GT86 & '22 GR86
Slip joints are known to leak, especially when cold. You may find that once upto temperature they will seal themselves up.
Unfortunately there is no real solution other than to replace the type of expansion joint. I have Gruppe-S UEL headers will slip joints, its yet to go on the car im undecided what to do with them.
Varelco is offline   Reply With Quote
The Following User Says Thank You to Varelco For This Useful Post:
BirdTRD (06-20-2017)
Old 06-20-2017, 10:41 AM   #13
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Yeah, I figured as much. All of my leak testing was done when they were cold. After getting the crack welded and not being able to get the slip joints apart without significant effort, I decided to put it back on as is since I found the true source of my P0171 codes (which is what started this whole thing)....a vacuum leak in my SC bypass valve, not an exhaust leak fooling the O2 sensor.
Now that it's replaced, all is good!
Old 06-20-2017, 10:48 AM   #14
Varelco
Thats good news, glad you got it all sorted!
My only other suggestion would be to have the header ceramic coated but leave the slip joint section uncoated. My understanding is these joints work by differential expansion between the two pipes. Coating one side will just increase this differential.
...well thats the theory anyway
FS: Tomei UEL Header FirestormFlex Engine, Exhaust, Bolt-Ons 5 03-22-2016 07:36 PM
WTT Tomei UEL header for catted UEL header ironsurfer129 Engine, Exhaust, Bolt-Ons 1 07-17-2015 04:33 AM
Ft86speedfactory UEL header vs, Tomei Expreme UEL Header WallsAndFoundations Engine, Exhaust, Transmission 47 06-24-2015 04:50 PM
Possible Leaky Taillight Fix Sco2355 Issues | Warranty | Recalls / TSB 6 02-18-2013 03:26 PM
