Old 02-17-2015, 04:18 PM   #1
PBlack09
PBlack09's Avatar
Drives: 2015 Scion FR-S Firestorm
Driver side mirror won't go up/down, door can't be manually locked
2 issues here:
Driver side mirror will move left/right, but it won't move up/down at all. Passenger side works perfectly.
Inside driver side door, the handle lock can't be locked manually. I can switch it to the unlocked position, but I can't move it back to the locked position and it feels like it's hitting something in the way. Although it locks if I use the door lock button or the keys. It's just manually moving the lock itself that doesn't work. (Not a big issue at all obviously, just curious why it's doing this.)
PBlack09 is offline   Reply With Quote
Old 02-17-2015, 04:43 PM   #2
marky
marky's Avatar
Drives: 2020 BRZ tS #54
Something might be wrong with the mirror motor/gear.. I don't advise this but try and move the mirror manually with your hand.. maybe it got stuck on a gear.. I moved mine around by accident and still works..
As for the door on the driver side it won't lock manually that's a safety so you won't lock keys inside.. but if you have the driver side door closed and go on the passengers side and lock it down manually it will close.. try it
Old 02-17-2015, 07:18 PM   #3
PBlack09
PBlack09's Avatar
I'll have to lightly mess with the mirror just to see if that works.
I could've sworn I've previously manually locked the door, but it does make sense. Either way, not a big deal. Just being cautious. Thanks for that.
Old 02-17-2015, 07:23 PM   #4
Koa
won't hurt the gears to manually move it a few times.. but something to keep in mind while washing if you're heavy handed, for sure!
Old 04-30-2017, 08:37 PM   #5
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
@PBlack09 did you ever figure out how to fix this? Mine is doing the exact same thing -- side to side works, but up and down is dead.
Thanks!
B-R-Z is offline   Reply With Quote
WTB Driver Side OEM Mirror Assembly FV Want-To-Buy Requests 0 01-06-2014 05:09 PM
FS: OEM Driver side mirror FerraraZ Exterior Parts (Aero, Lighting, Etc.) 7 12-08-2013 10:15 PM
WTB: Driver side mirror assembly JW89225 Want-To-Buy Requests 0 07-10-2013 08:32 PM
When doors are locked manually the car won't start whataboutbob Electronics | Audio | NAV | Infotainment 9 10-14-2012 12:10 PM
