2013 BRZ Rotors: Help please!
![]() I'm trying to figure out the exact dimensions of the stock BRZ rotors so I can buy them and get them installed. I auto-x casually (couple times a year) but mostly just want to spend as little money as possible. In the NASIOC thread I don't understand why there are three different sizes for the rear rotors? Are these correct? Vented or non vented for the rear? Anything else I need to know for the fronts? Fronts: 295x25.5mm Rears: 290x18mm https://forums.nasioc.com/forums/sho....php?t=1265631 EDIT: I've read the sticky threads but I don't really understand them. |
#2 |
Drives: 2013 WRB BRZ 6MT
Those seem to be correct. Our rears are vented. If you tell the shop you're buying from that you have a BRZ, they should be able to source the correct rotors.
#3 |
Drives: 2013 satin white brz limited
This is the setup I went with on my BRZ.
https://www.tirerack.com/cart/HoldingArea.jsp |
#4 | |
#5 |
Drives: '13 FRS - STX
I have these saved in Amazon for when mine finally get worn down enough. Note that they still have life at 60k miles, going on 3 seasons of autox and 5x track days, the OE rotors are stout as fuck.
https://smile.amazon.com/Centric-Par...=centric+rotor https://smile.amazon.com/Centric-120...=centric+rotor http://www.ft86club.com/forums/showp...9&postcount=14 |
#6 |
HP PLUS RACE BRAKE PADS
Premium, Autocross/Track Front: HB711N.661 Rear: HB671N.628 SPORT SLOTTED CRYO-TREATED ROTOR Front Drivers: 126.47021CSL Front Passenger: 126.47021CSR Rear Drivers: 126.47031CSL Rear Passenger: 126.47031CSR Total was around $500 Shipped. |
| Looking for OEM rotors | RickyRacer | Canada Classifieds | 2 | 09-14-2016 06:25 PM |
| 2013 STi Brembo calipers, pads and rotors | The Racers Line | Brakes, Suspension, Chassis | 9 | 05-29-2015 03:24 PM |
| Rotors | z3ro | Issues | Warranty | Recalls / TSB | 19 | 12-03-2013 12:01 PM |
| will wrx rotors fit the brz? | NYCsubaruBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 09-24-2013 08:58 PM |
| FS: GTS rotors | yomchi1989 | Australia Classifieds | 0 | 01-05-2013 01:33 AM |
