The Mechanic
Drives: Civic Turbo,FR-S
Speed by Design V2 turbo kit
SOLD SOLD SOLD
SBD 20g turbo with a billet compressor wheel, no play or leaks light polish and port matched turbine housing port and polish to WG opening to prevent boost spiking honey comb MAF air straightener installed in intake pipe to stabilize readings omni 3 bar MAP sensor included OEM oil pan with welded drain included turbo blanket included oil lines included. its basically everything you need except a tune. I also have my OFT and a base tune for this kit f/s that can be negotiated if you want a combo. It has about 9000 miles on the kit. I made alittle over 300whp @9psi with a 2.5in exhaust, full boost around 2800rpm. I turned up to about 13psi adjusted the tune and i was spinning 2nd and sometimes 3rd depending on tire temps. (the parts where just washed down when i took the pic) asking $2200
#2 |
The Mechanic
bump
#3 |
Drives: 2014 WRB BRZ
where are you located in NJ?
#4 |
Drives: FRS
If available in two more weeks I would like to get this!
#5 |
The Mechanic
im located centrally, but i will drive to meet up wherever.
ok cool pm me and see if its still here at that time.
#6 |
Drives: 16 BRZ Limited
Kit still for sale?
#7 |
Drives: Frs monogram whiteout
Pm me if its still 4 sale
#8 |
The Mechanic
I do still have the kit
#9 |
Drives: FRS
One more week and will be messaging you man! I want this so bad!
#10 |
Drives: Red Scion Frs
How did the car hold up and what's the reason for seeking the kit?
Sent from my SM-G950U using Tapatalk |
#11 |
Drives: Scion FR-S
still avaliable?
#12 |
Drives: Scion FR-S
pm pls
#13 |
The Mechanic
#14 |
The Mechanic
still no buyers with actual cash.
| To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? | xuimod | Forced Induction | 106 | 09-01-2016 07:33 PM |
| FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices | FullBlown | Forced Induction | 588 | 12-02-2015 02:41 PM |
| Bren5279's Full turbo partout (JDL uel turbo, Greddy Evo 3, AEM gauges, + More) VA | bren5279 | Engine, Exhaust, Bolt-Ons | 69 | 06-29-2015 10:56 PM |
| fs feeler full blown turbo kit minus turbo | kingkai23 | Engine, Exhaust, Bolt-Ons | 10 | 03-11-2014 02:59 PM |
