Old 03-15-2017, 11:57 AM   #1
c4lvinnn
Drives: Toyobaruion
HVAC Knob - Lit up or no?
Having a brain fart this morning and can't remember for the life of me if the HVAC temperature knob lit up like the other two knobs on the dial (when the acc lights are on). I could have sworn it did, but I don't remember for sure. The one in the red circle.
c4lvinnn is offline   Reply With Quote
Old 03-15-2017, 01:55 PM   #2
Nails
Drives: 2016 FR-S (Halo MT)
Yes, the spot you have circled is lit up like the other two dials.
Nails is offline   Reply With Quote
The Following User Says Thank You to Nails For This Useful Post:
c4lvinnn (03-15-2017)
Old 03-15-2017, 07:32 PM   #3
c4lvinnn
Drives: Toyobaruion
Well, that sucks. Guess an LED is out on the board?
Old 03-15-2017, 10:21 PM   #4
Nails
Let me qualify what I posted. There is no LED at those clear points on the dials. It is illuminated by a single bulb used for each of the two larger dials. So, if the red/blue temperature graphic on the dial is lit, the bulb is working. The stock bulbs are pretty dim, so it might not look like that clear part on the outside of the dial is lit.
Old 03-16-2017, 10:30 AM   #5
c4lvinnn
Drives: Toyobaruion
Right. I guess I should have clarified as well. The whole dial (behind the temp graphics, and the knob itself) does not light up. The only thing that lights up is the AC on/off button. That's why I swore I used to think it was lit up, but now it's not, so probably a dead bulb somewhere? I read through the changing the LED DIY guide here and not sure if I want to do mess with ALL that just to fix the light on that one (or what if the circuit on the board on that side is broken?). Or take it to the dealer and not have my car for a few days for them to fix it either, albeit under warranty. May just live with it.
Old 03-16-2017, 12:29 PM   #6
Nails
Yup, it sounds like that one bulb went out. I ended up doing the LED swap going by the DIY guide you mentioned. It was quite an adventure and I have become VERY familiar with the HVAC panel in the process. It doesn't take too long to take the car apart to get to the panel and the bulb would be a quick replacement using some long needle nose pliers. But, if your car is still under warranty, it would be easier to let the dealer take care of the problem. They should be able to replace the bulb in an hour or two at the most.
c4lvinnn (03-16-2017)
My HVAC - hot, cold, and not much else . . . geezerbrzeezer Electronics | Audio | NAV | Infotainment 22 03-02-2017 03:03 PM
HVAC Twist LED? xFury Cosmetic Modification (Interior/Exterior/Lighting) 2 03-09-2016 06:49 PM
BRZ HVAC Lorico Interior Parts (Incl. Lighting) 0 08-22-2015 01:01 AM
door speaker trim rings and HVAC knob covers BlackyRose Cosmetic Modification (Interior/Exterior/Lighting) 18 11-21-2014 05:15 PM
are you looking for HVAC knob covers for the BRZ? chenshuo BRZ First-Gen (2012+) — General Topics 6 07-25-2013 06:03 AM
