Old 02-05-2017, 04:14 PM   #1
dudeslife
How much "jiggling or play" is normal with the FR-S hood?
At 70-80 mph, looking down the driver's side line, the hood is rising up approx 1/4 inch and the hood seems to have some vibration. Is this normal? Thanks for any info.
2016 Halo Manual
dudeslife is offline   Reply With Quote
The Following User Says Thank You to dudeslife For This Useful Post:
FirestormHachiroku (02-08-2017)
Old 02-05-2017, 04:18 PM   #2
gramicci101
Off Topic
It's not uncommon. Crosswinds make it worse. It's not going to go anywhere though. Tested above 100 mph on a closed circuit.
Old 02-05-2017, 04:19 PM   #3
dudeslife
so nothing needs adjusting?
2016 Halo Manual
Old 02-05-2017, 04:23 PM   #4
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I doesn't really make any difference. You stop noticing after a while.
Scrappydoo is offline   Reply With Quote
Old 02-05-2017, 04:31 PM   #5
In order for the hood to close there has to be some play in the latch. Add the extreme light weight of the aluminum hood and the result is some lift when driving. All is good and nothing to worry about as long as it is flush when stopped.
dudeslife (02-05-2017), humfrz (02-05-2017)
Old 02-05-2017, 04:33 PM   #6
dudeslife
thanks! my analtivity is causing it to really distract me.. I find myself just staring at it when I am speeding down the interstate.
2016 Halo Manual
Old 02-05-2017, 04:50 PM   #7
All cars do it. The shape of the hood at the fender bulges on ours just make t more obvious than others. If it was flat it could lift as much but you just wouldn't notice it.
Old 02-05-2017, 04:50 PM   #8
arxm
Drives: 2013 FR-S, 2023 BRZ
this might be a dumb question but are you sure its closed properly and you haven't accidentally hit the open latch from inside. 1/4 inch of play sounds like the hood isn't closed
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 02-05-2017, 04:51 PM   #9
I doubt it is actually a 1/4 inch. Just seems like it. Love to see somebody climb out and measure it whale going down the highway.
Old 02-05-2017, 04:54 PM   #10
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
That would be whaley dangerous. Not something you'd do on porpoise
The Following 10 Users Say Thank You to Scrappydoo For This Useful Post:
arxm (02-05-2017), Celica00 (02-05-2017), dnieves (02-05-2017), enouf (02-05-2017), extrashaky (02-06-2017), gramicci101 (02-05-2017), gravitylover (02-06-2017), Guff (02-08-2017), Tcoat (02-05-2017), Ultramaroon (02-06-2017)
Old 02-05-2017, 05:01 PM   #11
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
i dont have this problem.
FR-Sky is offline   Reply With Quote
Old 02-05-2017, 05:11 PM   #12
Drive faster.
Celica00 (02-05-2017), finch1750 (02-06-2017), gramicci101 (02-05-2017), Guff (02-08-2017), kakacarrotcake (02-06-2017)
Old 02-05-2017, 05:21 PM   #13
arxm
lool yea i figured as much but i guessed he looked at a reference and measured. Fwiw its never happened to me
Old 02-05-2017, 05:26 PM   #14
winstonscifi
winstonscifi's Avatar
Drives: 2015 Firestorm Red Scion FR-S
Location: Plymouth Minnesota - just west of Minneapolis
After about a month, at 1000 miles, I brought my FR-S in for an oil and filter change ( I negotiated a free one during the purchasing process). I had noticed the same thing - the hood on the driver side was a little "loose". There were no questions asked, the technician adjusted the stops and it now shuts tight. I don't have any trouble opening the hood. The OP might just want to bring it in and have them check it.
winstonscifi is offline   Reply With Quote
The Following User Says Thank You to winstonscifi For This Useful Post:
strat61caster (02-06-2017)
BRZ replacement hood with "rdot" sticker rookie BRZ First-Gen (2012+) — General Topics 8 09-10-2016 01:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 03:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 07:34 PM
Just some F1 drivers in "normal" Ferraris.. CSG Mike Other Vehicles & General Automotive Discussions 16 03-15-2013 04:42 AM
