Drives: scion frs
Double din head unit
What double din head unit is a direct replacement for the stock analog pioneer unit?
Sent from my XT1650 using Tapatalk |
#2 |
It's going to depend on what you mean by "direct replacement".
If you mean plug-and-play, no additional fiddling around required you would have to go with one of the Toyota/Subaru units that come as an option. Those for the most part plug directly into the existing harness. For example, I replaced my 2013 basic unit with the AHA with Nav unit out of a 2014 FR-S. Easy swap and works great, but I'm no audiophile. Any aftermarket unit will require you to add a harness to the radio to work directly with the car harness, and with that some things like the remote mic may not work (it's a powered noise cancelling mike and won't work with most aftermarket units). You'll also most likely have to use a trim plate because the opening is not a standard size. All very doable but not what I would call a "direct replacement". Crutchfield.com does a good job of showing you what is available that will fit, and what accessories you will need to make it work.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#3 |
Drives: scion frs
Yes I want a plug and play that fits exact with no dash kit
#4 |
i think majority of DDIN will fit without needing a dash kit. wiring though is another story.
im not expert, but depending on what year your FRS is, you might need wiring for the backup camera and also wiring to ensure the stock USB port still works. |
#5 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Many aftermarket double din are too narrow compared to OEM. Probably better asked in the electronic subforum though and you can also check builds to see what people use and if it required a dash kit or not.
If you have the basic kit you could always look for an OEM touchscreen for a small upgrade http://www.ft86club.com/forums/forumdisplay.php?f=27 |
| The Following User Says Thank You to finch1750 For This Useful Post: | Tcoat (01-13-2017) |
#6 |
Drives: scion frs
Thank you
| FS: Like new OEM BRZ head unit w/ nav | inositle | Audio/Visual, Electronics, Infotainment, NAV | 2 | 08-26-2015 09:38 PM |
| Double Din Head unit | Subaru86 | Electronics | Audio | NAV | Infotainment | 2 | 08-02-2015 07:23 PM |
| Video Review: Sony XAV-712BT Double Din Head Unit with Mirrorlink | The Sentinel | Electronics | Audio | NAV | Infotainment | 0 | 07-07-2014 12:00 AM |
| Double-din head unit that support Korean? | frslee | Electronics | Audio | NAV | Infotainment | 0 | 02-26-2014 10:25 PM |
| Good double DIN head units | YW-Slayer | Electronics | Audio | NAV | Infotainment | 3 | 07-21-2012 11:57 PM |
