Old 09-04-2016, 09:08 PM   #1
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
Anyone running solid transmission mount?
I have recently installed my solid mount on mine and have noticed that it amplifies all of my exhaust vibrations. When I installed my CF driveshaft I noticed that the front pipe hanger is actually attached to the transmission. I thought for a while that my new driveshaft was vibrating at about 75 MPH on decal, but when I do it in neutral I feel no vibration. Has anyone else had experience with this? I was thinking of making some type of rubber grommet for the hanger or something to absorb the exhaust vibrations because I actually feel it in the floor, no shaking in the shifter though.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 09-04-2016, 09:16 PM   #2
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
What solid mount are you using?
gatorbushmen is offline   Reply With Quote
Old 09-04-2016, 09:42 PM   #3
Drakiv
Project Shadow
Drakiv's Avatar
the Megan Racing one
614whp/421tq on E85
Instagram: Drakiv
Old 09-06-2016, 06:02 PM   #4
Drakiv
Project Shadow
Drakiv's Avatar
I tested it a little more and its actually RPM specific, happens in all gears at around 3500-4k rpms. I never noticed before because I just haven't run the rpm's up that high yet really in each gear. I will see if there is something I can come up with to fix this and try and report back if anyone else ever runs into this issue.
614whp/421tq on E85
Instagram: Drakiv
Old 09-06-2016, 08:01 PM   #5
Drakiv
Project Shadow
Drakiv's Avatar
Here is a picture of the mount I am talking about that I believe is causing the vibration.
(this is MAP's picture not mine, just borrowed it to showcase the mount I am having issues with)
As you can see in the picture, the front pipe is directly connected to the transmission. Any vibrations previously were absorbed really well by the very flexible OEM transmission mount. Now that I am using the reinforced mount I am getting all kinds of exhaust vibrations. So what I am thinking of doing is possibly just drilling the hole out a little and inserting an oversized rubber grommet that the front pipe will bolt to and hopefully it will absorb that vibration.
614whp/421tq on E85
Instagram: Drakiv
Old 09-06-2016, 10:42 PM   #6
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Pick up a sheet of 1/8" silicone, cut to shape, sandwich on both sides of the hanging bracket, add 2 washers to the bolts, or cut and drill a spreader plate (preferred).
Vibration gone.
This. Good to 400 degrees F and not too sloppy at 50A durometer.
https://www.zoro.com/value-brand-rub...w&gclsrc=aw.ds
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
Drakiv (09-06-2016), SkAsphalt (10-24-2016)
Old 09-06-2016, 11:15 PM   #7
Drakiv
Project Shadow
Drakiv's Avatar
Vibration gone.
I will definitely try this out thanks for the tip.
614whp/421tq on E85
Instagram: Drakiv
Old 10-20-2016, 01:22 PM   #8
Pin Flare
Luna
Pin Flare's Avatar
Drives: 2016 FRS Release Series 2.0
Did you notice any transmission wine with the solid mount?
2016 FRS RS 2.0 #347 of 1000
2013 SCION FRS DEAD AND GONE THANKS TO A FLOOD.
Pin Flare is offline   Reply With Quote
Old 10-20-2016, 02:02 PM   #9
Jmk91
Drives: 2017 Brz Performance Package
Not trying to be rude but why would you use megan racing motor mounts? I personally wouldn't use megan for anything let alone an engine mount. You get what you pay for.. In my personal opinion I'd rather use a cracked oem mount than a new megan but that's just me.
Jmk91 is offline   Reply With Quote
The Following User Says Thank You to Jmk91 For This Useful Post:
Hostile_Kittens (10-25-2016)
Old 10-20-2016, 09:50 PM   #10
Drakiv
Project Shadow
Drakiv's Avatar
It's not motor mounts, it's the trans mount. To each their own.
614whp/421tq on E85
Instagram: Drakiv
The Following User Says Thank You to Drakiv For This Useful Post:
Joveen (09-02-2019)
Old 10-24-2016, 03:30 AM   #11
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Vibration gone.
I need to do this, badly! Same issues for me! (And I love the 3500-4500RPM range haha)
DIY - AVO Transmission Mount Insert Bushing AVOturboworld DIY (Do-It-Yourself) Guides 0 06-04-2014 08:19 PM
STI transmission mount jah29 Transmission and Driveline 1 03-14-2014 09:07 PM
Transmission rear mount Nitro_FRS Engine, Exhaust, Transmission 2 12-30-2013 11:49 PM
Transmission mount question Bullnettles Engine, Exhaust, Transmission 2 05-28-2013 12:22 PM
New cusco transmission mount! Silverdub Engine, Exhaust, Transmission 5 07-11-2012 08:50 AM
