Old 01-01-2024, 03:55 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
GTC-200 wing, smaller wing or no wing at all?
So I need to get a new setup on the car. I'm wearing the outsides of V730s in about 5 hours and the insides are at 80%. No idea what happened, but it's both sides and there is a lot of negative camber.
While I'm getting a setup done, I'm debating removing the rear wing entirely or just going to smaller one (if that's possible). I see ARP has deferent side plates, but they dont state how much of a difference they make. If it's a big difference, for $120, I'd start there (they also dont tell us the difference between the old, the new and the euro side plates)
It just pushes too much as it is, and I can't get much, if any, rotation on braking.
As far as running ST5, or similar, what is the general consensus for a wing- if there is one?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
GrandSport is offline   Reply With Quote
Old 01-02-2024, 02:09 AM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What’s the whole setup on the car? My biggest problem adding a splitter and wing(gtc200) was my suspension was no longer up to it.
Old 01-02-2024, 06:24 AM   #3
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Did you end up changing your suspension to accommodate it?
RongTurnRacing is online now   Reply With Quote
Old 01-02-2024, 08:52 AM   #4
GrandSport
GrandSport's Avatar
It has a small splitter, but I doubt it does anything. It's not low enough.
Suspension is is fine. Stance coilovers.
Old 01-02-2024, 11:15 AM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, future prof’d it when I did.
Old 01-02-2024, 11:32 AM   #6
RongTurnRacing
What did you end up doing? I ask because I just did the UCW wing and splitter from Verus. I'm running Shaftworks USA coilovers with 6k/9k springs and all spherical bearinigs. I'm hoping that's enough.
Old 01-02-2024, 11:42 AM   #7
M0nk3y
What are your rates? Alignment Settings, Swaybars etc. Coilover aside, something seems incredibly wrong on the setup side of things to be having this type of wear.
Sideplates won't change anything drastic what you're looking for. APR is notorious for having wings that produce too much DF for our cars in particular. They're draggy.
Kyle H. - #89 STX
Old 01-02-2024, 01:07 PM   #8
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Well the dampers themselves should be fine... Worst case its new springs and a revalve.
I would be curious what John says about your setup. 6k/9k is pretty common for non aero builds. But maybe its more slicks and aero that require stiffer springs than just aero alone
autoracer86 is offline   Reply With Quote
Old 01-02-2024, 01:42 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I am on Annx CSP’s on 10/12k setup now. I was on older T2’s on a 6k flat setup. I was bottoming the fronts a lot and the car didn’t want to rotate.
Old 01-02-2024, 02:27 PM   #10
RongTurnRacing
Good to know. Thanks everyone.
Looks like my 6k/9k setup needs to go to 8k/9k. Thanks to a couple of key resources for that info.
Last edited by RongTurnRacing; 01-02-2024 at 03:09 PM. Reason: Updated the information I discovered.
Old 01-02-2024, 04:01 PM   #11
CSG Mike
CSG Mike's Avatar
What is your current complete setup?
CSG Mike is online now   Reply With Quote
Old 01-03-2024, 08:46 AM   #12
GrandSport
GrandSport's Avatar
Front
-.10* toe (total)
-3.72* Camber
5.71* Caster
Rear
.12 total toe
-3.02 Camber
Stance coilovers (I know... they came with the car, they're honestly not that bad and my track is very smooth so its not a big deal)
gutted/caged/etc
small splitter
V730 tires
and obviously, the wing
Old 01-03-2024, 10:13 AM   #13
CSG Mike
CSG Mike's Avatar
Is that rear on both the front and rear or just the front?
Old 01-03-2024, 10:46 AM   #14
terboboost
terboboost's Avatar
Drives: 2013 BRZ HKS Turbo
Front
-.10* toe (total)
-3.72* Camber
5.71* Caster
Rear
.12 total toe
-3.02 Camber
gutted/caged/etc
small splitter
V730 tires
Stance coilovers are fantastic, is there a sentiment that they are not?
IG: @terboboost | Twitter: @terboboost | youtube.com/@terboboost | D-corp.co
terboboost is online now   Reply With Quote
FS: SARD LSR Style Carbon wing **wing only* brzzy Canada Classifieds 3 03-23-2017 09:58 PM
Does anybody have seibon gt wing or apr gtc200 universal wing on their car? spicyricecake Cosmetic Modification (Interior/Exterior/Lighting) 6 03-17-2016 08:38 AM
FS: Used OEM Limited Wing - Dark Grey Metallic - with STi wing gurney Enalband24 Exterior Parts (Aero, Lighting, Etc.) 10 01-03-2016 12:24 PM
Gauging Interest: Wing or GT Wing?! awang0528 Exterior Parts (Aero, Lighting, Etc.) 3 05-01-2013 12:12 AM
