Drives: 2013 Hot Lava FRS
Verify my installation of EBC
Hi guys,
I tried searching around but couldn't find any pics on how to install an EBC. So heres a picture to make sure I did it right. All good? |
#2 |
Drives: RX-7 / BRZ
EBCS electronic boost control solenoid
#3 to turbo inlet #2 to wg #1 vent to atmostphere -pigtail to teal harness under backside of uppder intake
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
| The Following User Says Thank You to Kiske For This Useful Post: | AdrianSaldana (07-18-2016) |
#3 |
Drives: Built FA20
That is strange. Port 3 is usually vent to atmosphere...
#4 |
Drives: Built FA20
![]() This makes more sense to me for an external wastegate. |
#5 | |
I Love custom Turbo kits
Drives: Limited BRZ
![]() I had this same question when installing my EBCS two years ago and was on the phone with Grimmspeed about it. They let me know this way in your picture and the way in the picture I posted above works fine. The picture I posted was a newer way to install the EBCS. The picture you posted is more suited for when you are pushing over 25 psi and need boost help to keep the spring closed and control it better.
#6 | |
Drives: Built FA20
| The Following User Says Thank You to nickw14 For This Useful Post: | Sportsguy83 (07-20-2016) |
#7 |
Plumbing is perfect then. Pretty sure it's the right harness spot too as it is hitting WG pressure. Just have to get it actively v on trolling now
#8 |
Drives: none
you may want to run your "vented" port back to the intake manifold. The way it's configured now you have a small boost leak while the turbo is spooling. Granted, it's a small boost leak, but even a small and intermittent boost leak can be frustrating when tuning.
-Matt |
#9 | |
Drives: Limited BRZ
#10 |
Got my new tune flashed and Confirmed it is working!
| The Following User Says Thank You to SirSpectre For This Useful Post: | Sportsguy83 (07-21-2016) |
#11 |
Drives: 2013 Ultramarine FR-S
After installing mine I noticed a drop in vacuum. Going to have to go through and double check for any leaks. Glad I hooked it up correctly though. Thank you for posting this.
#12 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Someone have a pic of where port 1 goes?
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#14 |
fastest frs in sbg
Yes if u want to come help me tomorrow lol ill be home all day. Ill pay gas n beer. Lol im in Sheboygan
| OEM Oil Cooler Kit and Installation DIY | SkiRideDrive | Engine, Exhaust, Transmission | 80 | 10-05-2022 09:49 AM |
| TRD Lip Spoiler Installation (GTA) | BG.Ghost8 | CANADA | 15 | 05-19-2014 10:44 AM |
| Need Help with Mic installation on OEM HU | mister.bond | DIY (Do-It-Yourself) Guides | 0 | 05-11-2014 02:10 PM |
| KW V3 installation problem | BAE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 05-04-2014 06:09 PM |
| Installation DIY (FOR YOU) | FRSure | Mid-Atlantic | 11 | 01-26-2014 07:51 AM |
